Question about SINGER 7470 Sewing Machine
How can I set the timing in my new Singer Sewing Confidence 7470?
The top thread is not catching the bobbin thread. I purchased this machine a month and half ago. Use it and made a couple of pj's. I didn't sew for a week or two and as of last night the machine won't sew. The nearest Singer Warranty Center near me won't answer their phone or return calls. I contact another over an hour away, The technician tells me it may be my timing and he will need my sewing machine for a week before I get it back. Is this timing something I can do myself? The needle is hitting the plate under the bobbin when I remove the bobbin case as the manuel says to clean that ares. Please Help!!! This should not happen each tiime I am ready to sew new projects.
  • montyirene
    montyirene Apr 19, 2013
    Hi did you get the timing sorted on your machine seem to have the same problem
SOURCE: singer sewing machine 7422
not paying for this
Posted on Apr 19, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
  • 111 Answers
SOURCE: I have a Confidence 7470
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
Posted on May 12, 2011
Testimonial: "Thank you so much for your prompt and thoughful assistance. I would definitely recommend your service to others."
  • 36 Answers
SOURCE: I was sewing with my
Yes, try looking very closely at the needle assembly. Make sure the new needle is loaded with the flat side against the arm that holds it. If the machine is only a few months old, it's probably under warrantee. There should be a number to call on the serial plate. If all else, call the store you purchased it from. Sometimes they have sales people who are well versed with their equipment and can help you but I bet the needle is facing the wrong direction when you replaced it. Find any broken pieces of needle and remove them too. Look with a flashlight. I hope this helps!
Posted on Sep 22, 2011
marigold1m
  • 3 Answers
SOURCE: singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Posted on Nov 28, 2011
Why is my bobbin thread showing on the top of my work. I have a singer confidence 7470 machine?
Your top tension is probably too tight. Loosen it up. If you are unable to get the tension where it should be, the bobbin tension may need to be tightened (just a TINY bit!). You don't want to make a big adjustment to the bobbin tension nor do you want to be constantly changing it. Generally, your machine's tension should be regulated through the top tension unit.
Understanding Thread Tension Threads
Mar 18, 2018 | Singer Sewing Machines
Singer conferdence 7470 not sewing
Try a brand new needle. If that doesn't work, then the machine is most likely out of time. Search for sewing machine timing or take it for service.
Feb 13, 2017 | SINGER 7470 Sewing Machine
Hi, I have a singer confidence 7470 sewing machine and the needle keeps hitting the bottom of the bobbin. I need to know how I can adjust the needle.
Try a brand new needle. If the old one is bent, that could be why it is striking. If the new needle doesn't resolve the issue, the machine most likely has a timing issue. You can search for multiple web sites and videos for discussions and instructions for sewing machine timing issues. Or you can take it for service.
Oct 04, 2016 | Singer 7470 Confidence Sewing Machine
My sewing machine jammed the fabric into the bobbin case and now it won't sew the needle hits the plate under the bobbin case can I adjust this myself
Here are some videos that may help. If not, search the internet for thread jam.
How to Fix Thread Jam Sewing Machine
When Thread is Caught in Sewing Machine Sewing Lessons
https://www.youtube.com/watch?v=tDcBUR0PcyA
If you get it unjammed, be sure to install a new needle as the old one is probably damaged. If there are still issues, the machine's timing may be off and would need professional service.
Oct 23, 2015 | Singer 7470 Confidence Sewing Machine
My singer 7470 i start to sew and clicks and bunches the cotton then the bobbin catches on the hook
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
if these suggestion don't help then the machine needs to be checked to see if it needs some type of adjustments
Mar 19, 2014 | Singer 7470 Computerized Sewing Machine
I was sewing with my Singer Confidence 7470 when it suddenly would not pick up the bobbin thread. I changed the needle, re-threaded the machine, and checked that the bobbin case is clean and in correctly...
Sep 22, 2011 | SINGER 7470 Sewing Machine
I have a Confidence 7470 purchased in May 2009. I was sewing tulle today and the thread kept snapping while sewing. I assumed it was catching in the tulle. The last time it snapped, the thread jammed in...
May 11, 2011 | SINGER 7470 Sewing Machine
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Bottom thread too loose; tried rethreading top thread, cleaning bobbin case, refilling bobbin, changing needle, adjusting top tension
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Dec 18, 2010 | SINGER 7470 Sewing Machine
I have a Singer confidence 7470 and when i sew something the string on the bottom part of the material gathers....i tried playing with the tension adjustment but it didnt work Your help would be...
First, make sure you have the bobbin placed correctly in the bobbin case. There should be a diagram showing the correct placement and thread path. Your upper tension should be set at "3." Then be sure the needle is inserted correctly...the groove should be toward the front of the machine. And just to be sure, recheck the upper threading. Sometimes one missed little thread guide will cause the problem you're describing. I hope this helps and that you can get your machine running again!
Nov 11, 2010 | SINGER 7470 Sewing Machine
SINGER 7470 Sewing Machine Logo
64 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
