Question about Sewing Machines
How to install cutter on a lock cutter (P/N 555790)
The cutter on my White super lock 1934D has dropped down and won't stay in the correct position to cut. How do I fix this?
The cutter mechanism connects to the machine whet the front is closed. If you look at the machine with the door open. You will see a finger coming out of the inside of the machine. If you turn the hand wheel it should move up and down. On the cutter mechanism there is a fork that fits over the finger. When it is all closed up it sould work together to move the cutter blade up an down. Is the cutter in the up position?
Apr 29, 2015 | Sewing Machines
How to clean wiper sensor on enterprise
Cutter blade needs replacement. Sensor is likely fine and is not located in the bobbin case area.
Sensor is telling you there is a cutter error. More than likely need a new cutter. Easy enough.
Cheers,
Kelly
San Diego, CA
May 09, 2014 | Baby Lock Sewing Machines
I need a visual on how the thread cutter looks when put back properly together
This was the best video I could find on the machine, I don't know anything about sewing machines but this might just help you.
https://www.youtube.com/watch?v=q-okTBWAHMs&list=PLsmrvZ1PDyoN-cFLYrfx8ovktM6PNo5RQ
May 01, 2014 | Baby Lock Imagine
Cutter not working
Are you talking about the trimmer knives?
Jan 05, 2014 | Baby Lock Ellure
Attachment "Lock Cutter" for Singer model #1120
contact singer customer service about the directions you need
Mar 04, 2012 | Singer Sewing Machines
Friday I purchased a new Baby Lock Ellure Plus from a dealer and have had nothing but problems since. It worked fine in the store. The problem I'm having is with the automatic thread cutter not
when you take it back, write down your questions on paper & make sure they show you that everything works before you take it home, that machine should run like a charm,,
Jan 28, 2012 | Baby Lock Ellure
How to install a lock cutter on singer 8280 sewing machine?
How do i install and use my lock cutter on my singer 8280?
Jan 03, 2012 | Singer 8280 Mechanical Sewing Machine
Using the cutter on the Baby Lock Evolve
As wide as you want, but anything over a few inches is going to be difficult to guide.
You will get a more even cut if you trim away most of the excess down to a few inches, like with a rotary cutter and mat.
Mar 11, 2010 | Baby Lock Evolve
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
