I have a samdung dvd player model HT-T2215 , when i want to make it on our open the dvd player , it show the " protect " alarm and turn to off . can you help me to solve the problem
SOURCE: Samsung HT-DB600
i think you hold down the stop button on the player for like 8 seconds or something while the player is off. that is suppossed to reset it.
Posted on Jun 13, 2007
tech48
  • 624 Answers
SOURCE: Protect error
This is a failure of the power supply or the amp. In either case, this unit is one that the boards are available and should be replaced. The first thing you must determain is which board is bad.
I have been repairing these since they started making them, and can tell you that it is not an easy task to figure out which board is bad. You will need a multimeter, and then know how to use it very well.
Sometimes you can get pointed in the right direction just by knowing what was happening when it went bad.
If the unit was working and you turned it off, then the next time you went to turn it on you started getting the "protect" message in the display, you most likely have a bad power supply board.
If you were listening to the system and it just shut off on you and then when you turned it back on you got the "protect" message, then it is most likely the amplifier board.
There is one more thing to check before you ever buy a board for this unit. If the fan in the back is not turning when you turn the unit on, it may only need a new fan. Lets hope that this is your problem, it is cheap and easy to fix. The other options may be better for you to take it to a service center to properly troubleshoot The boards are a little expensive, but that is what Samsung does with these units, they replace the boards. Most all other audio equipment from all other brands do not even make the boards available.
Check the fan first, if you need the part number let me know, I think I may have a manual to look it up for you. If you want to try and check the boards, I may be able to help a little more, but this is a very difficult thing to do over the internet.
I would appreciate it if you would wait until we are finsihed communicating on this problem before you rate it.
Thanks,  Dave
Posted on Jan 22, 2009
ginko
  • 19396 Answers
SOURCE: When i turn on my samsung HT-Z110, the word "Protect" appears...
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
MNfisherman
  • 11896 Answers
SOURCE: Protect Unplug
I know that almost all new equipment since 99 or so on up has these. They are too sensitive. This is a system program that will put stereo in protect mode when turned up loud or have a lot of bass on to stop from blowing audio outputs.
Posted on Aug 07, 2009
johex
  • 75 Answers
SOURCE: Power ON
over voltage to the system causes ur system to shut off.
get it checked or replaced if  warranty is still valid.
Posted on Mar 14, 2010
My aiwa dvd player HT-DV90 won`t stay turned, in the screen shows PROTECT and turns off ...
Check the speakers one by one, maybe one of them are damaged and make the device going on protection
Aug 26, 2011 | Aiwa HT-DV90 System
I have a samsung HT-Z120 it show a PROT error
This error means that you are trying to play a region-protected disc that is not in the same region as your player.
It is possible to "hack" the region on your DVD player by following these instructions:
http://www.videohelp.com/dvdhacks/samsung-ht-z120/10244
Please rate my answer.
Thanks,
Chris
Mar 05, 2011 | Samsung HTP-1200 System
SHOWS "PROTECTED" THEN SWITCHES OFF.
hi m8 did u find out how 2 do the " PROTECTED " ???my dvd player do th same
Jan 11, 2011 | Samsung HT-TZ215R Theater System
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Apr 02, 2010 | Televison & Video
Aiwa ht-dv90
Not good protection is a special circuit in side the machine.. You will need to get the machine repaired at a service center. You circuit board has over loaded.
Oct 09, 2009 | Aiwa HT-DV90 System
Samsung HT-Z110 DVD Player shows HELLO when turning on followed by PROTECT then turns off.
Hi! my unit is the same model as you have, actually i only resolder the power supply board. and it turned ok try what i did it might solved your problem.
Sep 22, 2009 | Televison & Video
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Need help with Media Player
WMP 11 will _ONLY_ install on a "genuine" copy of Windows. The only ways out of the "PROTECTION" error: * start in Safe Mode, and use System Restore to go "back" in time to a date before the problem started; * reinstall Windows from *GENUINE* media.
Dec 25, 2008 | Samsung HT-TX72 Theater System
Samsung dvd home theater HT d5610
This sounds like a short circut (check speaker and other conections to make sure none are touching each other or a metal contact!
That should fix ya!
Dec 18, 2008 | Samsung DVD-R155
Samsung ht-tz212 protect!
resistor smr60 is 470r / 470 ohm
Nov 08, 2008 | Audio Players & Recorders
75 people viewed this question
 Grubhead
Grubhead
