Question about Broan-NuTone QTXN110HL Fan
Heater doesn't work
Exhaust fan is ok. Heater's fan is ok. It blows out cold air when I turn the heat switch on. Regular light and night lite are working fine. What should I do? Thank you so much for your help.
Danny Dao
  • 2 more comments
  • Danny Dao
    Danny Dao Jan 29, 2009
    Thank you so much. It's great.
    Sincecerely yours,
    Danny Dao
  • Anonymous Mar 29, 2014
    The light & exhaust fan works okay.
    Heater & blower does not work. Light & exhaust fan works fine.
    Scholar:
  • 95 Answers
You can purchase heating elements for this fan that will solve the problem. This is a fairly new fan model so I would recommend calling Nutone because this model has a three year warranty. They may send you the part you need for free.
Posted on Jan 28, 2009
I have a york diamond 80 heater. The part that blows the heat out won't come on.. igniter lites and flames come on but blower doesn't..help we are freezing
Sounds like your fan switch is defectiveor posibble installed in the wrong place. This switch is heat controlled and delays the fan coming on until there is warm air to blow.
Dec 31, 2012 | Heating & Cooling
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
1993 dodge spirit heater fuse
The heater is NOT actuated by a fuse, the fan is. ]But if the fan blows, the electrical part is OK, then it must be the heater door that switches from the cold air to the hot one, or 2) the heater core is not receiving enough hot coolant.
Dec 07, 2011 | 1993 Dodge Spirit
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
Air/heat not blowing from vents, can feel the heat but it's not blowing, I turn the knobs to high blow and it won't do anything, its cold outside,
if the fan does not increase speed as turned up replace resistor assembly usually in heater housing under dash.if doesn,t nave separate resistor assy.it is the fan switch
Feb 11, 2011 | 2002 Buick Century
Truck heats up, leaks water from the muffler, and blows cold air when heater is on
water out the exhaust is normal it means your engine is running strong and cooling correctly. your heater blowing cold air is because your heater failed what you do is turn the fan on and were you here the fan motor turn on the heater core is in that box to find were it is pop the hood and look for the coolant hoses going in to the firewall thats your heater core cap the lines remove the dash open the blower motor box and pull the core out note the way it came out because the lines are supply and return usually one is bigger than the other the bigger is the supply
Feb 15, 2010 | 2003 Ford F150 Regular Cab
No heat air is blowing cold
First you have to identify what causes the problem.
To do this you have to:
1) When engine is cold check the level of coolant. If it is low fill it up.
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced.
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is worm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
4) If pipe/pipes are hot/warm, turn off the fan, switch controller to the hot position, wait for 3-4 minutes and turn on the fan. Note if the cold air blows first or warm air blows first but it cools down in 5-10 seconds. If the air blows cold than it is most probably the problem with blend door or blend door actuator.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest to flush the heater core.
Oct 22, 2009 | 1998 Ford Taurus
MY 1998 FOR TARUS HEATER WILL NOT WORK.WAS DRIVING
It is most probably the problem with blend door or blend door actuator. But just in case I would suggest to follow the entire procedure:
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is warm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest flushing the heater core.
Oct 17, 2009 | 1998 Ford Taurus
Heater not working
Pliot is lit...no heat
check to see if voltage to gas valve if no replace or check wires
Jan 06, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Broan-NuTone QTXN110HL Fan Logo
642 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
