Boiler programmer acl lifestyle LP722 instructions
Programmer instructions required 2004 model
3 Suggested Answers
  • 2558 Answers
SOURCE: My ACL lifestyle lp522 doesnt turn heater off
Hi it sounds like it hs worn inside exchaning it would be the cheaper option
Posted on Feb 01, 2010
Testimonial: "thanks"
SOURCE: acl lifestyle lp522
The display should not be blank, meaning nothing there to look at. Different digital thermostats can be powered in 3 ways. Just from their battery's, from the furnace control transformer, from the furnace control transformer with battery back up in case the control power fails to retain your programming. Usually, removing it from the base and pulling the battery's to kill ALL of its power, waiting a minute or so then re-powering it, will restore the factory program and return the display. Also, there may be a small fuse on the back of the stat. If it has one, it will be easy to see if you are looking for it. Easy to miss if just looking at it for no reason. Be sure there is power to it. The battery's and their connections first. If you have a meter, check for control voltage. Put one lead on "R" then touch the other to "C", "Y" or "H". Should have 24 volts (AC) from the furnace transformer. I have never seen a stat blow from a power outage. But?
Posted on Dec 18, 2013
Acl lifestyle lp522The power supply went off in my house and now the programme panel has no power to it even though the mains is now live. Is it broken?
Try removing it from the base and remove the batterys to kill all its power. Be sure the batterys are OK with good contact. Wait a minute and put it back together. If the factory program doesn't display, its probably bad.
Dec 18, 2013 | Heating & Cooling
Hi, I am having problems with the timer that controls my boiler. It is a 'Lifestyle LP522'. The hot water is set to come on in the morning for 4 hours and again at 4pm for 3 hours. The heating is...
then there must be a problem with the programmer as the boiler thermostat will call for heat only if the programme is on try setting the water side to 24 hrs it won't cost any more to run , but will prove if programmer is working .
Mar 07, 2017 | Heating & Cooling
My central heating pump does not switch off when the acl lifestyle model lp722 central heating timer switches both the hot water and c/h off. pump keeps running through the night
if you can turn off the hw and ch off , to the off postion and it shuts off then the acl lifestyle could needreplacing mine did the same on ch only so changed mine , or check the divtervalve is working and not stuck in the open postion , try turning hw on and off only then the ch see if valve works
Jan 08, 2011 | Heating & Cooling
Could you tell me where i can get a instruction manual for central heating thermostat Lifestyle Model Lp722
Try with this:
cgi.ebay.co.uk/...MANUAL...LIFESTYLE-THERMOSTAT-/200541444128
Helpful?
Jan 01, 2011 | Heating & Cooling
Boiler not switching on when thermostat is changed
Double check your boiler water levels. You may be overfilled.
Feb 09, 2010 | Heating & Cooling
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
I have just had a new boiler fitted and wanted to run the thermostat (honeywell cm921) on auto, the electrician set the timer to come on at 1 & off at 2 disabled at 3 & 4 and on again at 5 and off...
Complicated because I need more info....but in General a Boiler should not be on a Programmable Thermostat as it takes too long to heat etc...do you have Radiators in your house???Or ductwork for heat???It will make a difference...if you put the boiler on a program it may come on anyway as some boilers maintain there own internal temperature regardless of the thermostat.....if you want to run it on a program adjust the temperatures so there is only about a 2 degree swing....70...down to 68....back to 70.....etc...there should also be a switch in the thermostat to set for Boiler...or Electric heat...make sure that switch is on...otherwise its difficult to give you a more conclusive answer
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
Changing boiler programmer
take digital pictures - label all wires and reconnect - you do not need manual.
Oct 27, 2008 | Water Heaters
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
