Question about Mustek DV-4500 Camcorder
Colour missing on parts of mini dv tape
Hello i have the colour missing on my recent movie, when i fast forward the tape the colour appears and as soon as i switch to play back the colour disappears this is the foirst time i am having this problem it is both for pc and camcorder playback, please help.
0 characters
1 Points
How do I clean the head when it gives you an alert?
two ways, buy a mini dv cleaning cassette, two if you do not have one, put the cam in play mode, hit play, than fast forward button for a min, the tape going fast sometimes cleans the head. not just fast forward but play, than ff so the tape is hitting the head, other than that, the cam has to be taken apart and the heads cleaned with the proper cleaning solution and PROPER brush as not to hurt the fragile heads
Sep 15, 2014 | JVC GR-D250 Mini DV Digital Camcorder
Canon DM-XM2 Will not record or play back
Clean Idler unit it is magnetism and clean sensor it will work
Mar 08, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
flexible wire connecting between LCD board and camera main board is cracked or broken and requires replacement.
Let me know to provide you part number of flexible wire if you want to replace it yourself.
Feb 02, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Tapes will not play
Video head is dirty / clogged. Use good quality Mini DV Head Cleaning cassette.
Oct 01, 2008 | Sony DCR-HC32E DV Digital Camcorder
Unable to record
Check this page--i think this is a problem with this whole line of camcorders...
Jul 28, 2008 | JVC GR-D73AG Mini DV Digital Camcorder
Mini DV damaged
You have to make sure that when the tape was put back in the cassette, that it maintained it's side to head integrity, in other words, that it did not flip so at a certain point, the back of the tape is running against the drum and head in the machine. If that is the case, then you should insert the tape and rewind it and fast forward the tape 2 or three times and then let the tape rest for a day fully rewound or fully fast forwarded. This should iron out the small wrinkles, but unfortunately, the big creases in the tape will cause a loss of information so the picture will fail. You should transfer the tape immediately to your computer and burn a DVD as your tape has a very short life span now,
May 15, 2008 | Canon ZR100 Mini DV Digital Camcorder
PV GS39 Win XP Movie Maker
I don't know if Windows XP Movie Maker can detect a firewire based video camera.
Do you have DVD burning software such as Nero in your computer? That has capture capability to it.
Pinnacle Studio will detect a firewire camera. It is reasonably priced and easy to use. In fact you can control your camcorder from Studio in case you need to rewind or fast forward the tape.
May 14, 2008 | Panasonic PV-GS39 Mini DV Digital...
Help it's going to fast
Your camera has a capstan servo problem which is more than likely being caused by the capstan motor itself.Nothing you can do youself,would suggest bring to service but reccomend getting estimate before repairing.
May 23, 2007 | Panasonic PV-GS31 Mini DV Digital...
Panasonic DVC 7
Clean the heads with a Panasonic MiniDV cleaning tape. I've seen many cameras come through our shop with this problem - a quick cleaning made a world of difference.
Mar 13, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Horizontal green bars whenever I play my tape!
I've had a similar problem that I've solved using a head cleaner. I think it was about $20 at Target and is good for 30 cleanings.
Nov 14, 2006 | Samsung SC-D363 Mini DV Digital Camcorder
Mustek DV-4500 Camcorder Logo
Top Mustek Video Cameras Experts
Larry Stiles
Larry Stiles
Tom Chichester
Are you a Mustek Video Camera Expert? Answer questions, earn points and help others
