Bizhub 350 error pull out drawer on tray 2 and bypass
2 Suggested Answers
SOURCE: error c1183 on bizhub 350
Check this solition
Posted on Dec 02, 2009
Error c-0910
C-0910
The Lift-up Sensor is not blocked even after the lapse
of a given period of time after the lifting motion has
been started.
Basically your paper tray 2 did not lift right. Open the tray and make sure the paper is loaded correctly. The paper should be touched on all four sides by the tray or by adjustable guides. Open and close the front door with the tray out. Once the machine is ready to copy close the drawer you should hear a slight buzzing sound as the tray rises. If you don't or you hear a banging or grinding sound the tray lift motor may be damaged and you will need to call a service technician.
If the code keeps coming back pull out tray 2, open and close the front door to reset and leave the tray 2 partially pulled out until a technician can repair.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c-0960 how can i reset it
C-0960 error code is for the bypass tray on a C350 copier. Make sure there is nothing binding up the tray lift mechanism. To reset open the front door, on the right side where the plastic starts to curve you will find a small hole, in that hole there will be a small button. Use a pen tip or a paper clip to press this button, this will reset the error. If the error returns there may be damage to the bypass lift system.
Apr 12, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Drawer 3 won't open
Drawer 3 is LCT, Large Capacity Tray. if the LCT is not opening, then perform following steps to get rid of this problem. 1-Press the LCT or 3rd tray (large cabinet) inward, and wait for a while.you will see that Tray will open automatically. 2-If the 3rd large tray cabinet is not opening then turn around the machine, at the back side of the 3rd tray, you will see a small hole downside at the back of the tray. Insert screw driver or any pointed thing which can easily go inside.after insertion press the screw driver or thing which you are using inward.the 3rt tray will open.
Mar 02, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do I remove drawers 1 and 2 from Bizhub C200 - am getting error code C0204
Pull out the trays, locate the metal tab on the copier frame that is held in with one screw. Remove the screw and angle the tray out.
Feb 14, 2010 | Konica Minolta Bizhub-200 Minolta Printer
How do I get our Bizhub 350 to print on envelopes.
Create your document at the appropriate size, #10 Env.
On the device, set the BYPASS tray to a size setting of the same. Look under the custome sizes as there may already be one there.
There is a switch just inside the device, near the bypass tray where you set it for envelopes. this opens up the feed gap to allow for the thicker envelopes.
this is all contained in the manual.
Dec 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Jun 29, 2009 | Minolta bizhub 200 All-In-One Printer
Printing on thick paper (thick 3)
You can print thick 3 only from bypass tray.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
May 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error code C-0211 Konica Minolta Bizhub C-351
It's called "Manual Bypass paper lifting failure". The manual says to check Tray 2 vertical transport motor. Check the wires to see if the are okay. Pull out tray 2, remove back cover, remove wire assembly from 4 wire saddles, remove 2 screws and the motor assembly. The should be 2 motors on the assembly and the one u need to look at is the bottom one. hope this helps.
May 22, 2009 | Konica Minolta bizhub C351 All-In-One...
Can't get transmission report on bizhub 250 to print in Portrait
to change the tray that reports print from
it can be changed in service mode soft switch 323
change bit 7 to a 1 to print from tray 1
change bit 6 to a 1 to print from tray 2
bit 5 to 1 to print from tray 3
bit 4 to 1 to print from tray 4
bit 3 to 1 to print from bypass tray
Mar 19, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Mar 29, 2008 | Minolta bizhub 200 All-In-One Printer
k24674
jasbo
jasbo
