Question about Radio Communications
Pairing code for IO Play Bluetooth Stereo Car Kit
  • 740 Answers
SOURCE: nexxus bluetooth car kit
To pair you must first turn bluethooth feature ON on Sony phone. This usually has an indication on lcd display when it turned ON (it looks like a headphone sign) the you must turn visibility of your phone ON making it ready to be paired. Following instruction that came with bluetooth kit put bluetooth in pairing mode when its in paring mode led lights will rapidly fash. At this point you phone should pick up bluetooth if it doesn't then do a search for bluetooth devices with your phone and it will find the bluetooth (make sure its in pairing mode) It will display the bluetooth type and model number. It also may ask for security code if it does it 0000 set by default. Then pairing should be complete just save and you should be good to go. Good luck and thanks for using fix ya
Posted on Jan 28, 2009
  • 5 Answers
SOURCE: Unable to pair Nokia N85 to Parrot car Kit
It's possible that you need to reset the parrot - seems it might only accept pairing with one phone. On mine you hold down the red and green keys together until she tells you that she is clearing the memory, then she prompts you to pair your phone
Posted on Jul 05, 2009
SOURCE: I have lost the instructions for my Vodafone BT visor bluetooth
I have the instructions if you would like to give me your e-mail address i will send them to you
Posted on Jul 24, 2009
SOURCE: what is the pairing code for a pama visor mounted
Hello Give this a go
Sunvisor range
PNG8......8888
PNG9......8888
PNG10....8888
PNG11....8888
All The Best Jon Bodley.
Posted on Jan 08, 2010
SOURCE: What is the pairing code for the Bluetooth 10799
I just bought one and the code was "8888" Hope this helps
Posted on Apr 30, 2010
I have an Alpine CDE-SXM145BT car stereo. that will not play Bluetooth devices.
Have you had the battery removed at any time before this happened or been jump started ?
Apr 09, 2017 | Alpine Car Audio & Video
I have entered the wrong pass code into my lg G4 phone for pairing a nexus dsp Bluetooth sun visor car kit but it will not let me enter the correct code,
Hey Ged Gage,
Unpair the car kit, by going into the G4's bluetooth settings and then pair again... Hope that helped!
Jan 01, 2017 | LG Cell Phones
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
How do i pair my jabra bt250 to my htc desire hd
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
I need to send a password from the phone to the car how do I imput it on the phone. the password is 1111
Power on the Bluetooth on your car stereo and MP3 player or cell phone. The Bluetooth may always be on in your car, but it may be disabled on other devices to conserve battery power.
Open up the menu of your cell phone or MP3 player and have it "discover new devices."
Select your car stereo from the options your device provides.
Enter in the "Pairing Code" for your car stereo into your device. In most cases you will find the pairing code in your car's manual. if you don't know the code try using all )'s.
Try playing a song once your device indicates it is paired with your stereo. If it doesn't work try
Steps 2 to 4 again.
Use 0000 instead.
Thank you.
Mar 12, 2011 | Cell Phones
Need to pair jabra Bluetooth car kit with mobile phone
You need to put the Car Kit in pairing mode, usually done by starting with the power off and holding the power button till the light flashed Red and Blue or solid Blue.
Then search for the car kit from your phone. Once found pair using pin code (pass key) 0000 or 1111 or 1234.
May 04, 2010 | Jabra Bluetooth Car Kit with Night Driving...
Unable to establish a connections with home stero and car
This is how this device works: regarding its bluetooth part, this device is able to handle handsfree (HFP) and headset (HSP) profiles, which are meant to be used by previously paired bluetooth enabled phones, for phone calls purposes only, and Advanced Audio/Video Distribution (A2DP) and AudioVideo Remote Control (AVRCP) profiles, which are designed for stereo music, coming from previously paired compatible bluetooth sources, to be received and controlled (play/pause/prev/next). The only purely transmitter part of this device is its FM funcion, i.e. it receives A2DP streams from a bluetooth enabled device (e.g. computer, smartphone) and converts them to a predefined FM station, so that your car (or home stereo) can tune up and sound on their speakers.
Summarizing: the T505 bluetooth car kit receives phone calls and stereo music from bluetooth enabled sources and either sends them to its own loudspeaker, or converts them to a predefined FM station, to be tuned by another device.
If you happen to need its user guide, you can download it from here.
Please, let me know if I can help you any further.
Regards, Carlos
Mar 20, 2010 | Motorola Mobility MOTOROKR T505
Blue tooth compatible Car stereo ..and LG Voyager wont pair
The pass key is the password the bluetooth accessory has. So your car stereo manufacturer has a code that you enter on your phone, so that someone nearby with a bluetooth cell phone won't be able to hook to your stereo - it's usually in your owners manual for your stereo or bluetooth speaker system.
Most bluetooth headsets have a passcode of 0000, and it's the same for Motorola headsets, plantronics headsets etc. You may be able to lookup the passcode for your bluetooth speaker system in a manual online, if you no longer have it.
Mar 25, 2009 | LG VOYAGER VX10000 Cellular Phone
Code for bluetooth car kit
Also note that some of the IHF1000 carkits may also use 1234 for the passcode. When you go into the Setup Menu and ask it to Pair a Phone, the prompt will tell you the correct passcode (0000 or 1234) to enter by saying, "Enter xxxx, when requested".
Nov 24, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
Radio Communications Logo
16 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
