Question about Brother HL 5140 Laser Printer
Brother hl 5140 printer status green but error message nothing prints
ctf1800
  • 4402 Answers
SOURCE: Brother HL-5140 printer
make sure you have the drum seated all the way in, then unplug the printer and plug it back in.
Posted on Feb 20, 2008
voodoomox
  • 1689 Answers
SOURCE: Brother HL-5140 red status light on
RED status light means that there is a possibility that the internal circuit might have got damaged (cracked to be exact). This would require a professional to fix the problem. So, the best thing to do would be to call Borther techsupport because they will instruct you specifically on what to do and what needs to be replaced (also you may need to consult the device's warranty status)
1-877-BROTHER
Brother Tech Support
hope this helps, good luck on this one.
Posted on Aug 04, 2008
yooperbud
  • 8637 Answers
SOURCE: Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
SOURCE: HL-5140 Brother laser printer red status light remains on.
Help me, please . Red status light on. PC recognises printer. Nothing happening. Toner was on for a few weeks. But now new toner cartridge and still solid red light. What is this?
Posted on Apr 29, 2009
  • 214 Answers
SOURCE: red status light on. won't print,
Try this.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000071/HL5100_UG_ENG_3.pdf
Posted on May 01, 2009
Our HL 5140 won't print. The status light and paper light is flash, yet there is paper in the tray.
Hello ,
Please follow the below steps to try and clear this message.
  1. Turn the power off on the unit.
  2. Open the front and back cover of the unit.
  3. Remove the drum and toner cartridge from the unit.
  4. Check thoroughly inside for any paper jams or any other foreign objects and remove them.
  5. Reinsert the drum and toner and close the front and back cover.
  6. Turn the unit back on.
This should clear the error message on the display screen and allow you to resume normal use of the printer.
Thank you,
Pat
Mar 26, 2010 | Brother HL 5140 Laser Printer
I cannot get my brother HL-5140 laser printer to print anything!!!!!! I have tried all troubleshooting suggestions.light on status is red
There is some paper jam inside the printer .Please remove the cartridge and look inside the printer for paper jam. If paper jam is there , remove the paper . I hope it will help to solve the printer problem.
Jan 25, 2010 | Brother HL 5140 Laser Printer
HL-5140 model. the paper light is flashing and
Hi Patricia,
Try to do a factory reset on the server.
Whilst the printer is turned off, press and hold the GO button as you plug the printer on to the socket. Notice that all lights on the printer will turn on as well. Continue pressing the go button until the light for the toner goes up and once its up, release the button. Next, hold down the Go button again until the "Yellow Status" light turns on once on, release the Go button. Wait for the printer to initialize and see if the error went away.
Hope this helps.
Jan 05, 2010 | Brother HL 5140 Laser Printer
All 4 lights are on. I cannot even get it to print a test page
Follow the instructions below to solve this problem.
  1. Turn off the printer power switch.
  2. Take out the DIMM (Dual Inline Memory Module) from your priner, if you have a DIMM installed.
  3. Wait a few seconds and turn the printer back on.
  4. Try to print again.
    If the error still remains, press the Go and the Job Cancel button together to check the error status referring the LED indications below.
  5. After checking the error status, report it to your dealer or Brother Customer Service.
Oct 23, 2009 | Brother HL 5140 Laser Printer
HL-5140 laser printer, refilled toner and red light still on.
sorry, the only way it is not only refill the toner, you need to change a little chip a green squar, who sold you the toner will can find to you
Jul 18, 2009 | Brother HL 5140 Laser Printer
Tonner flashing HL-5140- will not print at all, drivers are good
If you have the user manual look on page 3-1 for Control Panel. The different patterns of on/off/blinking lights indicate what the problem is. If the toner is flashing and status is green, your toner is low and should be replaced....
If you don't have the user manual it is at this link:
see page 3-1 or page 81
Jan 18, 2009 | Brother HL 5140 Laser Printer
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
1-877-BROTHER
Aug 04, 2008 | Brother HL 5140 Laser Printer
Feb 20, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
37 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
