Question about Canon Image Runner Toner Black 5050/5055/5065/5075 In Factory Box
Canon IR5055 Jam Error code A17
Present a Jam error code A17, but there is no Jam. Where do I look for sensor or guides that may be the cause. Location code 0 mostly (copier).
printech
  • 159 Answers
SOURCE: E00002-0000 error code
ont. Panel, press the following, one after the other, * (additional functions), 2, 8, * (additional functions). You are now in Service Mode. Touch the Function Tab, touch the Clear button, touch the ERR button, when it is highlighted, press the OK button at the botton of screen. Power Cylce unit. If it comes back up, may have been a fluke. However, if it comes back, check your Fixing Assy for jammed paper, or damage to the Fixing Film (Upper Roller). Replacing the Film is not hard. After you remove the Fixing Assy., its a couple cables and springs. Rather on the easy side for Film replacements. Remebmer, on these models, the Film is also the Heater and Upper Fixing Roller. The Film is most likely on the pricey side for new, believe you can find rebuilds. Just keep in mind that the Film is still a lil' bit cheaper then the whole assy., and 8 out 10 times, its the Film that fails in the asssy
Posted on Mar 23, 2008
  • 4 Answers
SOURCE: Our Canon D860 Copier has an system error code
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Posted on Apr 24, 2009
SOURCE: Canon Pixma MP198 error code 2 114 0
i got a same prob..i can't print,scan and copy and the refill warning always appeared..i hv refill the cartridge and i shut it down and try again and again..it's the cartridge prob or the printer prob..?
Posted on Apr 10, 2010
pineworks
  • 4041 Answers
SOURCE: My canon ip2600 printer has a paper jam error, but there isn't.
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
SOURCE: My Canon imagerunner 3300 displays an error code
plz help me at the problem E00051-000
Posted on Jul 01, 2010
Canon ir c2550 error code e000025-0001
Dear
The error code indicates the toner is not supplying for (Y). The hopper motor is locked. The probable cause the sensor is not detect within 5sec. when motor is on at hopper assy. Check. the sensor,clean-replace,check the jam of motor gears,check the harness up to DC con board, check the DC con board.
Thanks.
Jan 14, 2015 | Canon Office Equipment & Supplies
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
ERROR CODE E000354-0002
A Canon IR5055 is gaving me a error code 000354-00002. Can some one gave me the solution.
Oct 31, 2011 | Canon imageRUNNER 3225 Black and White...
Whay does an error E000000-0010 on a Canon IR5055 mean?
A E00000-0010 means you have a problem with the fuser unit. I would try to rest the error code first in service mode. If you had a power problem, the copier may give that error code. If it will not reset, you have to fix the fuser unit first.
Apr 04, 2011 | Canon Office Equipment & Supplies
Ir5055 error codes E0025
Toner hopper stiring motor (M9) error. Will require a service call by a Canon service tech.
Feb 23, 2010 | Canon imageRUNNER 5570 Copier
3 yellow flashes, then 1 green on a Canon PIXMA Ip4000
3 flashes is a GREAT symptom report. We need some more than that, but it does give us a direction.
If this is a "Service Call Error", it will be accompanied by an on screen message that includes a "6000" error code.
Here are the possible solutions....
- Timing sensor unit (QM2-1213)
- Timing **** disk film (QC1-4833)
- Feed roller ***'y (QL2-0598)
- Platen unit (QM2-1215)
- Logic board ***'y (QM2-1548)*1
- PAPER FEED MOTOR (QK1-0550)
These solutions are not for the novice, but are user servicible for many out there.
If this is a "Operator Call Error", it will also be accompanied by on screen error codes
Paper jam. [1300]
Paper jam in the under guide. [1304]
Paper jam in the rear guide. [1303]
Solution: Remove the jammed paper, and press the Resume/Cancel
button.
OR
Front door closed. [1250] Open the paper output tray.
Get a free copy of the service manual by contacting me at www.Equipmentcity.net
Sep 29, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Error code 5700
5700 is a ASF cam error most likely. Here the Canon proceedure for fixing it!
DESCRIPTION: 5 Alternating Blinks (SFP) / ##356 (MFP) - ASF Cam Sensor Error
SOLUTION(S): Adjust the Screws & Main Case Unit
Movement (i.e. from shipping) may cause the plastic guide to move away from the chassis. When this
occurs, the gears cannot rotate properly causing a grinding noise and 5 alternating blinks (SFP) or ##356
(MFP) - ASF Cam Sensor Error.
Procedures
  1. Remove the Left and Right Covers and the Main Case Unit (main cover).
  2. Remove the 4 mounting screws from the Chassis.
  3. Remove the Main Unit from the Bottom Case.
  4. Turn the Main Unit over (upside down) and place on work surface.
  5. Inspect the ASF section of the Main Unit for a gap between the white plastic guide and the Chassis.
    Note: The size of the gap varies. Even if the gap is not visible, complete the steps
    below.
  6. Disconnect the appropriate cables and remove the Logic Board from the Chassis.
  7. Loosen (do not remove) the 4 mounting screws (the mounting screws can be found behind the
    logic board) on the Chassis.
  8. Re-seat the white plastic guide so it sits flush against the Chassis. The tip of the white plastic
    guide should sit slightly inside the
    mounting screw hole. When seated correctly, the gap will no longer be present.
  9. Tighten the 4 mounting screws without
    causing the plastic guide to shift.
  10. Reassemble the printer and retest.
Sep 25, 2009 | Canon Pixma iP4500 InkJet Printer
Error code 840 on a canon ir5055 photocopier
E 840 is a shutter motor error. This is in the fixing assy. If it is a fresh in stall make sure to follow the right installation procedure.
Oct 03, 2008 | Office Equipment & Supplies
Canon Image Runner Toner Black 5050/5055/5065/5075 In Factory Box Logo
62 people viewed this question
old marine
old marine
