Question about Sony Dual Shock 3 Controller for PlayStation 3
Triangle button sticking
My dual shock 3 wireless controller triangle button is sticking, to scared to open it up. Its brand new bought a month ago
  • 71 Answers
Try a little rubbing alchahol on a Q-tip. do not drip in to controller, just rub around the button and press the button a few times. might have to do it a few times, let it dry before doing it again. It will break down what ever is sticky.
Posted on Mar 15, 2009
Brand new Sony dual shock 3 analogs not responding like my other ps3 controllers
Take it back to the shop if it is under warrantee. Don't mess with it and destroy your warrantee.
Mar 11, 2014 | Sony Dual Shock 3 Controller for...
Ps3 controller manual
You plug in the usb cable to charge the controller and connect it to the ps3 for the first time. You use the left analog stick to move around the dashboard when the ps3 is turned on and the 'X' button to change settings, go to the online browser, playstation store, or start a game. You can back out by pressing 'O' or holding the 'PS' button, which allows you to change a controller number (say controller #1 to #2 with two controllers), turn off the system or turn off the controller. Press (not hold) the controller to look around the dashboard while in a game and select say "Quit Game', or go into settings and change something around to your liking. Every game also comes with the controls and for what the buttons are. (Stick on left is the, "Left Analog Stick," right is "Right Analog Stick," from right to left starting at the green triangle shaped button is the, "Triangle," "Circle," "X," and "Square," buttons. The four buttons on the left going in all directions is the D-pad, and the triggers on the back going from the top left to bottom left and top right to bottom right are, "L1," "L2," "R1," "R2").
Feb 05, 2013 | Sony PS3 DualShock3 Wireless Controller...
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
Ps3 controller triangle circle box and x buttons wont work
Was anything spilled on it? This is likely cause for buttons to stick or become unresponsive. Has the controller taken any major impact? I.E thrown at wall? If none of these, take a pin or paper clip, turn controller over, and gently push the reset button. I do not recommend taking controller apart, as springs for the triggers are easily broken and will void and legitimate repair done by Sony.
Oct 28, 2010 | Sony Dual Shock 3 Controller for...
X button on PS3 controller not working
Hey i bought my controller from gamestop brand new for 60$ and after 8 months same thing happend to me.
I think it happend because i tunrned the ps3 off incorrectly and i corrupted some data , i could fix that dat because the data corruped was those files for recognizion of the "X" button.
To restore it you will need a PS3 Dvd/Bluray controller to go the XMB and restore using that controller.
Jan 31, 2010 | Sony Dual Shock 3 Controller for...
Sixaxis controller turns left
The solution is simply to buy a new controller, or get a cheaper one like 'madcats' or 'Logitech' which is about half the price of the SONY brand.
But you need to consider this if buying a brand other than SONY;
it might not last as long maybe about 6 months-a year before it gets funny with the controls. Also, most of them needs a USB receiver and batteries for the controller to use wirelessly for PS3. Which I think is troublesome, cause you can't charge it like the SONY dual shocks, and have to spend more money for new batteries or rechargables. You also need to sacrafice a USB slot on the PS3 for the receiver to work wirelessly with the controller, and I have no idea what the response is like when playing games, it might not play as smoothly as the original SONY Dual Shock.
May 01, 2009 | Video Game Consoles & Games
Buttons working in some games but not others
hey, i'm having probs with my controllers and came across this thread after reading your problem. i don't know if it will help but here it is...
http://gametz.com/forum/USER%3A78922/topic/273454.html
Jan 28, 2009 | Sony PS2 Dual Shock 2 Controller...
Hey there I have used a "SMALL" amount of baby powder, its non conductive so you dont have to worry about static...just rub a bit around the edges of the buttons depressing them as you go. Work it in and blow off the excess. Try that its a quick fix i have used in the past. anymore problems with it answer back. Hope it works for ya
Jan 28, 2009 | Sony Dual Shock 3 Controller for...
Logitech wireless controller for PS2
make sure you put batteries in the controller
also if you bought a new controller cuz you lost your old card or something take the batteries out of the old one itll interfere
and you have to press an action button on the controller
(the x,circle,square,and triangle buttons)
if all else fails use your old dual shock and trade the cordless into gamestop for a used controller
(if it wont work theyll replace it for free)
Jan 03, 2008 | Logitech - Cordless Game Controller...
Sony Dual Shock 3 Controller for PlayStation 3 Logo
456 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
