Question about Avanti EWC4001DZ Refrigerator
Hello, where can I buy parts for Avanti EWC4001DZ?
The parts are LCD PCB Cool Fan Mask Cool Fan Cooling System PCB
3 Suggested Answers
  • 87 Answers
SOURCE: avanti issues
Take this unit back even if you bought it used and get a new one it is still under warranty.
Posted on Oct 07, 2008
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Posted on Feb 17, 2010
Avanti RM440W mini fridge not cooling.
Hello Dave;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check.
1.) Door Not Sealing Tightly - I addressed this problem by raising the front end of the unit to assist the door in remaining tightly closed.
2.) Bad Thermostat - This is a long white tube about 1/8" in diameter mounted on the liner wall.
3.) Freezer Compartment Iced Up - You only have one cooling source and that is your freezer compartment. If the compartment is full of ice and frost you will not get good cooling.
4.) Refrigerant Leakage - Most Probable - The freezer section is made of formed very thin plate. The raised contours are also very thin. Your owners manual advises not to use hard steel tool to defrost. All to often, my customers use hammers and screw drivers to defrost and nick the contours. Run you hand across the cooling plate. If you feel a oily substance, then you have a refrigerant leak. If you have a service contract, it is less expensive to replace the unit than repair the seal system.
Dec 28, 2014 | Avanti Refrigerators
System fan
Some cpu cooling fan especially on laptop are basically have sensor. There is a certain temperature in order to make the cooling fan activate, when if it's cool then the cooling fan turn off automatically. Same with the air condition thermostat. Good day.....
Other way is to buy a usb cooling pad that fit the size of your laptop. If keeps cool your laptop though and i tried that already and it's effective to cool down the temperature.
Jun 29, 2013 | Compaq Computers & Internet
Ir400 fan numbers
II. FANS
A. Arrangement and Functions
Feeder fan
Fixing assembly heat discharge
fan 1***
fan 2 ***
Laser driver cooling fan
Laser scanner motor cooling fan 1
Laser scanner motor cooling fan 2
Cleaner heat discharge fan
System cooling fan
Reversing guide cooling fan
Low-voltage power cooling fan 1
Low-voltage power cooling fan 2
Reader cooling fan 1
Reader cooling fan 2
Drum cartridge cooling fan 1
Drum cartridge cooling fan 2
Drum cartridge cooling fan 3
DC controller PCB cooling fan
Scanner motor cooling fan
Function
Draws copy paper to the feeding
belt. Helps feeding.
Discharges heat from around the
fixing assembly.
Cools the laser driver PCB.
Cools the laser scanner motor.
• Cools the laser scanner motor.
• Insulates the drum cartridge
against heat from the fixing
assembly.
• Discharges heat from the
drum cleaning assembly and
fixing assembly.
• Discharges heat from the DC
controller PCB.
composite power supply and the
DC controller PCB.
Prevents curling of paper.
Discharges heat from the lowvoltage
power supply.
Cools the reader (image processor
PCB, laser driver PCB).
Cools the drum cartridge.
Cools the DC controller PCB.
Cools the scanner motor.
Aug 28, 2012 | Canon imageRUNNER 400S Copier
How do you turn on the cooling fan on a lc xa20? Projector turns off because off overheating and i cant figure out how to turn the fan on.
If the cooling fan is not on, it is probably faulty and needs replacing or is jammed up.
Check the air filters are not clogged up.
Jan 03, 2011 | Eiki XGA Avanti Series LCD Projector...
Nov 20, 2009 | Avanti WC3201D Wine Cooler
Cooling system
All the parts that you mentioned are the correct parts that you need to check if there's a problem with the cooling system in your jeep. It's just that you missed to check two (2) things:
1. Freon
2. Leak
If there's a leak in the copper tube, your car will run out of freon. If the freon is low, then the jeep will not get cool.
Contact an A/C tech to check if there's a leak, fix it and recharge your jeep with freon.
Have a great day!
Oct 04, 2009 | 2002 Jeep Grand Cherokee
Freezer fine but refrigerator is warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 03, 2009 | Avanti FF1101W Top Freezer Refrigerator
FAN MOTOR FOR 1995 MERCURY COUGAR XR-7
If the fan is electric it may just not be running when the engine is cool enough. Be sure to check it when your engine is hot, after you've been driving for a while. The battery may have a bad connection somewhere. Can the battery move when your accelerating? If so you should repair/replace the mounting hardware for the battery. Check the wires and connections to/from the battery and tighten/clean anything that is loose or dirty.
Jan 06, 2008 | NMB Technologies Fan Motor Case Cooling...
Pc automatic turn off
see the system temprature is cool it happen normally bcoz ho heat see your graphic card fan is working fine and it is not generating more heat. bye
Sep 12, 2007 | Acer AL1916W 19" LCD Monitor
Avanti EWC4001DZ Refrigerator Logo
24 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
