Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
The red convergence on the left is going to the left and up, and the center is perfect, then the right the red goes just a little to the right
  • 1 more comment
  • LakinL2 Feb 04, 2009
    exactly the same
  • Anonymous Feb 08, 2009
    i have same tv and same problem
  • the_jenkins Feb 14, 2009
    Right on , Man I appreciate it , I really do. Thanks allot!!!
  • Philips Master
  • 3,459 Answers
You need to replace the convergence chips and possibly a few resistors. Its a fairly easy fix. You can get the parts online from various sources or you can just get a complete kit from www.TvRepairKits.com
Posted on Feb 13, 2009
My RCA P52960 52in. rear projection tv has what looks like a slight Fisheye lense look to it,the center being perfectly fine but all around the edges is a slightly blurry and can see all three...
We calling convergence problem.
Re solder fly back terminal ( transformer)
Replace pico fuse 400mA(little red box fuse) beside fly back.
Go to set up, convergence, select auto convergence and your TV will work perfect.
I will be here for any future question.
Thank you for visit fix ya.
Aug 04, 2011 | RCA P52960 52" Rear Projection Television
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Sony KDP57WS550 Projection tv red, green and blue virtical outlines on left and right sides
This is a convergence problem. You will need the stk's changed and a pico fuse or 2. also from looking at the pic you might want to clean the lenses and mirror after the repair to bring back some of the vibrant colors the set once had when it was new. This repair should run you anywhere from $300-$500 depending on your area and the tech that comes out. If you need more information or would like to try to fix it on your own please let me know.
Tim
Sep 10, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Convergence
u could try changing the convergence ic if that is not it then u have to go in to the back door of the eprom to set but i think pansonice u need a service remote to get in. i hope this will hp marty
Jul 17, 2008 | Panasonic PT-51HX41 51" Rear Projection...
PT47WX52F Convergence problem, 3-d look, green worse
So you are able to adjust? the crosshairs move left and right up and down. you might have to get a tech to adust it in service mode.
Feb 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Red lines, Help??
when you replace the convergence amp board. u usally have to go into setup. or service mode and manualy converge the set. these settings are what perfect focus basis it reconvegence on. sort of the factory settings. these faint lines may also be a red crt overdriving too
Jan 03, 2008 | Samsung HCN5527W 55" Rear Projection...
Red shadows on images
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 18, 2007 | Pioneer SD-643HD5 64" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
RED
to do a proper convergence alignment always use your geen as refferance to work from bring the red and blue to the green also find the center of the screen and on the top and bottom to be sure your geen is centered then start/g
Mar 19, 2007 | Samsung PCN5425R 54" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
