Question about Frontgate Digital Photo Converter
Need Frontgate photo converter driver - Frontgate Digital Photo Converter
Where can i find instructions for use?
Contact Frontgate's Product Specialist team by calling 800-537-8484 or e-mailing ps@frontgate.com
Mar 15, 2015 | Frontgate Trio Jewelry Cleaner with...
How do i change battery on vornado remote
it may be held on with a tiny screw.. it needs removed before you can open it up
Aug 01, 2014 | Frontgate Vornado Tower Circulator Fan -...
How do I Open the Vorando Tower Fan to clean
Use a flashlight to look through the vents on the front. You should see screws.
Mar 24, 2014 | Frontgate Vornado Tower Circulator Fan -...
How to put it back together
Here is a link to the item on the manufacturer's website. You should be able to locate the manual there.
Jan 27, 2013 | Frontgate Golden Rotating Tree Stand -...
I want to know if my Nespresso Pixie D60 has a fuse protection because i plugged my 120 volt 60hz machine into a 220 volt 50 hz power supply without a converter.has my nespresso completely burnt and ruined...
There is not a fuse for protection from this insitent. However the damage on your machine is deoent from how long you left it on with 220v. It can be damage full but it can also not hapent anything. Have you check it again with 120V, since there is a chance that it can still work normal but in any case if not working you may need only a small repair by an eperience percon.
Sep 23, 2012 | Frontgate Nespresso Pixie Brown Machine -...
I brought a European LG outdoor heater to the USA and want to convert it to LPG. Where can I find the parts? It seems that all the terminations need to be metal fitting and rubber hoses with hose clamps...
Very tricky, EU gas runs on a different mbar pressure to US. It's not just changing the parts but also making sure it is legal to operate and it will need to be tested to CSA standard. In EU they have a CE certificate - this means nothing in US. For info on LPG gas see gas types, might be best to just buy a new burner head that is already converted to run on US LPG pressure.
Feb 21, 2011 | Frontgate Stainless-Steel Outdoor Patio...
Can I convert my Frontgate 38" Series 1 natural gas grill to burn on tanked propane?
hi my name is mark, i called frontgate they can ship you the conversion kit. the phone # is 800-537-8787. i would have a professional install the kit. thanks for your question.
Mar 05, 2009 | Frontgate Professional 38" Grill
Frontgate Digital Photo Converter Logo
57 people viewed this question
Top Frontgate Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Frontgate Office Equipment and Supply Expert? Answer questions, earn points and help others
