Question about Ducati 1199 Panigale GPS Lap Timer and DDA
Broken Ducati 1199 Panigale GPS Lap Timer And DDA
2016 Ducati 959 wont start, it has spark, tank is full, I have checked all the fuses and still cant find the problem
Hi, Elvia and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. Fuel injectors stuck open.
13. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a cursory reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
14. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
15. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
16. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
17. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
18. Faulty neutral, clutch lever, or kickstand safety switch.
19. Faulty fuel pump or fuse or relay.
20. A stuck bent or burnt valve.
21. Tilt sensor needs a reset.
22. Security system not disarming alarm needs a reset.
23. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Issues starting my new 959
New Panigale 959 Problems getting it started
https://drive.google.com/file/d/0B99ZG8WTqrhAMF90SHdOeU1DYTA/view
Ducati Omaha Ducati OEM Parts Ordering Diagrams Ducati Parts
Ducati Maintenance
Sep 05, 2017 | 2016 Ducati Panigale 959
Parking light ok no highbeam but pass light works
Hi, Anonymous if your headlight is not working, keeps burning out or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.,
How do you replace headlight bulb Ducati ms The Ultimate Ducati Forum
Upgrading Ducati Monster Headlight with Silverstar Ultra H4 Bulb
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Mar 11, 2014 | 2004 Ducati Multistrada 1000 DS
Fixing a new screen
The mirrors do have to come off, they attach the sides of the windscreen. As long as your patient you can do it. The hardest part is the bottom 2 screws. You can kind of (gently) pull the top fairing a bit, it does have some give. If you can pinch the rubber screw between your middle and pointer finger and slide your hand down and hold it until you get the screw started. Get them all started and keep them loose until you get the mirrors back on, then tighten it all back up. I personally would not want to glue anything. Make sure you have good lighting that will help.
Jan 20, 2014 | Ducati Motorcycles
Fault finding
Hi, Anonymous and the usual suspects are:
1. A severely drained battery.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
Backfiring
Backfiring SS ducati org forum the home for ducati owners and enthusiasts
Ducati Maintenance
Jan 14, 2014 | Ducati Motorcycles
Ducati 749 cutting out
Hi, Anonymous the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. Gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and free downloads that you need please visit the websites below. Good luck and have a nice day.
916 randomly cutting out Ducati ms The Ultimate Ducati Forum
ducati 999 spark plugs
Ducati Maintenance
Jan 31, 2013 | Ducati 749 Motorcycles
Rough idle and exhaust detonation at deceleration
Ducati Suite Performance Modifications
Power Commander Motorcycle Fuel Injection Tuning Module
2004 2006 Ducati Monster 400 620 Motorcycles Service Repair Manual Highly...
Ducati Maintenance
Jun 06, 2012 | Ducati Monster 620 Motorcycles
1976 Ducati 860 GTS - backfire
Backfiring
http://www.ducatimonster.org/forums/general-monster-forum/202081-exhaust-backfire.html Ducati 860 GTS GT 1976 1999 Service Repair Manual Download Manuals...
Ducati Maintenance
Mar 04, 2012 | 1976 Ducati 860 GTS
Backfiring on my ducati s4r
Hi, Francisco and the usual suspects are:
http://www.ducatimonster.org/forums/general-monster-forum/138799-s4r-backfire.html
Hiccups or Backfire
Ducati Monster S4R 2003 2006 Factory Service Repair Manual Download...
Ducati Maintenance
Jan 29, 2012 | 2007 Ducati Monster S4R Testastretta
How do i replace a broken finger in the clutch?
Hi, Daddydiggemd sorry you can't find the first and best tool you ever bought for your Ducati despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
help fixing my clutch on 2002 748 ducati org forum the home for ducati...
Clutch replacement Ducati ms The Ultimate Ducati Forum
Ducati Maintenance
Apr 28, 2011 | 2002 Ducati 748
Tomtom 1 3rd edition
Have you tried resetting the unit? All it does is show you 1199, no matter what numbers you type?
Feb 20, 2008 | Tomtom ONE GPS Receiver
Ducati 1199 Panigale GPS Lap Timer and DDA Logo
Top Ducati GPS Experts
Will Halftowaite
Are you a Ducati GPS Expert? Answer questions, earn points and help others
