Mywashing machine getting E2 display - Washing Machines
  • 15,935 Answers
E2 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
The play uten is not working on mywash
could be the actual button itself needs replacing on the board. or it could be your door switch is not engaged and the machine won't start.
Nov 10, 2013 | Hotpoint Washing Machines
E2 error on homemaker washing machine. I have tried eveything including reducing load down to one item. It goes through the wash cycle OK, but will not drain, then eventually flashes the E2 error on its...
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Sep 13, 2009 | Washing Machines
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Cloth stocked up under spinning basket
is the agitator loose? the dogs may be worn.
Oct 28, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
