Question about Panasonic PV-GS35 Mini DV Digital Camcorder
No power; can't eject cassette
The PV-GS35 just quit working suddenly while filming, and I can't get it to power on with battery or cord. I really want to get my recorded cassette out of the camera without damaging the tape at least. Anyone know how? Thanks, Pete
  • 139 Answers
Pete Check your Battery Contacts and see if they are Corroded or dirty,plus if there is a Memory batt pull it then keep both batt off for 30 mins Charge the one in your Charger if your charger is eqipped with refresh,Enable it but first Clean contacts with Pencil eraser ttech Hope that helps ttech
Posted on Jul 24, 2007
SOURCE:
Model PV-D4732. How can I get cassette to eject?
When you press EJECT, the tape has to be withdrawn into the cassette and the shutter closed before the cradle can be lifted to clear the spindles and allow the cassette to be shoved out. You will have to disconnect power and remove the cover to expose the complex inner workings and I suspect you will find a tangle of tape or a broken tape. Some careful work with appropriate tools will allow the tape to be stuffed back into the cassette or (worst case) cut out. You can apply power again and you may be able to observe the sequence of ejection operations before reinstalling the cover.
Dec 23, 2015 | Panasonic Televison & Video
Pv-gs35 sdhc formatting win7
SD cards go up to 2GB in size. SDHC cards go from 4GB to 32GB.
The PV-GS35 works with SD cards, not with SDHC cards. Your 1GB and 2GB cards are SD cards. Your new 16GB card is an SDHC card. While SDHC cards fit into the slot, they are electronically incompatible and will not work in devices not designed for them.
Jun 12, 2012 | Panasonic PV-GS35 Camcorder
Sony CCD-V200E Wont Eject
It is possible that the processor could be locked up and if you remove are power from camcorder for 30Min, no battery and no ac adapter either, and it should reset back to normal and let you eject tape.
Apr 09, 2012 | Sony Video Cameras
I just got my Dad's PV-GS35 and the sound doesn't work at all. What could the problem be and how can I fix it. It quit working when he was in Guatamala about 2 years ago and he didn't know until he got...
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 13, 2010 | Panasonic PV-GS35 Mini DV Digital...
Sx-70 is Not Ejecting FIlm When Taking Picture
Possible you got a bad film cassette. In the original Polaroid camera packs they had batteries which actually powered the whole camera. The batteries may be dead or not have much charge in them. They are good for a couple years and as you indicate the expiration is up in another month... Good luck
Aug 04, 2009 | Polaroid 600 Business Edition Instant...
Using PV-GS35 as web cam
I use an USB video adapter plus the program:
ulead video studio 8.0 se dvd
and it does work on my skipe.
I hope it helps
Jan 15, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
Push the reset button
This error indicates a cassette mechanism malfunction.
It happens usually when you don't operate the camecorder for long time
leaving the cassette inside and the battery attached.
Solution:
1. Open the cassette housing and nock GENTLY with your finger tip
on the cassette cabinet (particularly on the position marked "push") until
the cassette is released.
2. Push on the right place (marked "push") to close and then close the
cassette housing
3. Operate the cassette (play, fast forward/backward).
Repeat the above steps several times until the problem is gone.
Advise: Remove the battery and cassette when leaving the camecorder
for long period without being operated, and store the camcorder in a
dust/humidity protected place.
Hope this can help.
Jan 10, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
PV GS 35 wont play tapes from other cameras
perhaps it has to do with the SP and LP settings, I know certain video editing programs won't capture video recored in LP.
Aug 18, 2007 | Panasonic PV-GS35 Mini DV Digital...
Open Questions:
Panasonic PV-GS35 Mini DV Digital Camcorder Logo
114 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
