Question about Hotpoint Microwave Ovens
Hotpoint RVM120 001
No power. Unit smoked, smelt like wires. Is there a fuse inside these units?
3 Suggested Answers
  • 4088 Answers
SOURCE: Unit not getting power
These machines seem prone to having a bad magnetron. Look for a circuit breaker near the power cord entry point. If tripped, reset and try to heat a cup of water. If it makes a loud buzz and then pops the breaker again, the consensus view is a bad magnetron. This is one repair that is recommended to send out. (~$150). You need to evaluate the probable cost vs a new machine.
Posted on Nov 17, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Hotpoint rvm1435 microwave: seemingly no power
In addition to the fuse, the safety devices which will render the oven dead during a fault condition are the bottom TCO and the cavity TCO.
The TCOs (thermal cutouts) have thick black wires connected to them, and they should both read "closed" or zero ohms when you do a continuity check on them.
Do not confuse the hood TCO, which has thinner red and blue wires connected to it and which are supposed to normally read "open" or infinity. If the hood TCO were bad, the hood vent exhaust fan would run all the time.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Nov 26, 2011
No power at unit. Power to plug
Jim, Take the screws out that hold the cover on your unit and then take the cover off. Find where your cord goes into the machine and follow the black wire from the cord, it normally should go to a small circuit board and your fuse is usually mounted on that circuit board. It will be a 15 amp fuse and you usually can get one of those at most appliance parts stores. If there is not a circuit board the black wire may go directly to an in-line fuse holder. Hope this helps.
Aug 11, 2014 | Hotpoint RVM1635 Microwave Oven
My hotpoint oven lost all power while cooking
Might be a fuse inside, or the unit may have died. Contact the manufacturer and keep the unit unplugged.
Feb 13, 2013 | Hotpoint Hot Point - RVM1535MMSA Cooking...
No power. outlet is good, microwave plugged in. no lights, no power, nothing. does this unit have a power supply that might have gone bad?
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Nov 06, 2011 | Hotpoint RVM1435 Microwave Oven
My jmc7000 jenn-air blew a circuit breaker. No power to the unit. There is power to the recepticle. I'm wondering if it blew a circuit breaker, does that mean the problem is most likely a big problem...
Yau say a few conflicting things. First you wonder if it blew a breaker, and then say you have power to the receptacle. If you have poer to your receptacle your breaker if not tripped. There are NO breakers Inside of the Microwave. Only 1 time fuses. So, if your init is dead it has probably blown a fuse inside of the unit. If that is the case. Probably shorted HIgh volt capacitor would be my first guess. If it is jsut dead. it can be other things than just a blown fuse. bad thermal protectors, bad low voltage transformer on main circuit board. Burnt wires. Anything that will cause it to lose power inside the unit. From bad parts to bad connections.
Aug 16, 2017 | Jenn-Air JMC7000 Microwave Oven
Hotpoint rvm1435 microwave: seemingly no power (no lights work, no buttons work, etc); however a voltage tester shows electricity inside the unit. I tried replacing the fuse, but that was not it...any...
Aug 24, 2011 | Hotpoint RVM1435 Microwave Oven
SET TIMER FOR 20 MINUTES FOR BAKED POTATOE.. CAME BACK AND FOUND POTATOES CHARCOALED. SMOKE AND SINGED INSIDE. MICROWAVE WILL NOT COME ON. CHECKED CIRCUIT BREAKER. POWER TO UNIT.
That was a very long duration to have set for potatoes. It would have made the magnetron burnt by exeeding the limit and findinf there was no conductive medium by moisture , it has ended up burning the magnetron.
First of all clean up the inside and clean up the point of the magnetron beam.Now confirm on the inside to be totally dry.
Disconnect power and check inside for break of fuse to the magnetron.If the microwave does not heat on testing with a cup of water , then it is possible that the magnetron is cooked.
Confirm the cost for the unit to decide on replacement.
Hope this helps.
Aug 21, 2010 | LG LMV1630 Convection/Microwave Oven
Hotpoint RVM 225 BL 002 power reset. Internal breaker?
You can find helpful exploded view diagrams and order parts by entering your full model number here.
I would suspect the fuse or magnetron thermostat.
May 15, 2010 | GE Microwave Ovens
Ok , I replaced the fuse checked all connections and checked plug for power ! Still my lg lmv1630st will not show any power at all . What gives?
by replacing the fuse you meant the house circuit fuse or the microwaves internal fuse? and by conncetions your talking the internal wiring inside the case of the unit or wiring from the plug? if not its your 15 or 20 amp ceramic fuse inside the unit,if thats blown replace,but chk h.v.diode,v.v. cap,triac,control board, mis-adjusted interlock safety door switch,and lastly the mag could be defective
Aug 15, 2009 | LG Over-the-Range Microwave
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Hotpoint Microwave Mod. # RVM1435WD001 Stopped warming
I just had the same problem with my over the range microwave in my RV. I took the unit out, took the cover off to expose the inside and found that the magnatron was fried (where the wires plug into the magnatron, the plastic shield was melted). I ordered a new one from repairclinic.com for 126.00. It was very easy to install, only one screw held it in.
Jun 30, 2008 | Microwave Ovens
Microwave Ovens Logo
76 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
