Question about Focal BUS 25 - 10" Subwoofer with Amplifier
Focal bus 25 not loud
Conecting bus 25 with one rca lead
Removing back cover of focal xs
Be careful. RCA input plates are very difficult to pull anything out of, or push out. I would try to use a very strong magnet and hold it over the end of the port and try to ease it out with the magnet but keep the magnet AWAY FROM THE SPEAKERS AND HAVE THE DEVICE OFF WHEN YOU DO THIS!!!
Jan 09, 2014 | Focal XS 2.1
RCA 27F634T LED blinks 25 times
SDA [Serial Data] bus is busy or interrupted. Seek tech support. This is a very skilled work, need all measuring instruments, and through knowledge in electronics.
Jun 10, 2012 | RCA 27F634T TV
Which is the better way to wire my focal 33v dual voice coil sub, parallel or in series?
i would have to say witch ever one is were you conect the voice coils togather they will work to full compacity sorry i dont remember witch one is witch i hope this helps please give me a good rating
Jul 08, 2011 | Focal 33V Car Subwoofer
I have a paradigm ps 1000.it powers on fine when i plug in the rca cable into thoe back of the sub into the low level input it humms supper loud. i tested my cable and used another one same thing. could...
It sounds like it has bad ground on the RCA input assembly, you should Ohm out the ground of the RCA jacks to see if they are all connected.
How about the sender side (the amplifier) ground?
Mar 09, 2011 | Paradigm PS1000 Speaker
Volumen to conecting to circuit
Center pin goes to R115 right leg goes to C84
witch leads to the base of TR10 left leg to
ground.this is off aschematic of 25 LTD should
be close.
Good luck
May 23, 2009 | Cobra 25 NW LTD 40-Channels Base CB Radio
Aux input for sony car stereo (cdx c 5000r)
For Sony Stereos, you will need to get what is called a Bus Converter. The RCA ports you are trying to use are for a CD changer or alternate device like satellite or HD radio, and those have to have some sort of frequency signal to even be selected. You can find a Bus Converter that will allow you to use this as an Auxiliary input. The device you are looking for is called a Sony XA 300, and it will allow you Two extra Aux Inputs, I believe.
Jan 24, 2009 | Car Audio & Video
RCA Inputs for Pioneer AVM P100
An I-Pod connection box connects to the RCA inputs and the IP-BUS connection.
Here is a picture from the AVM P7000R manual showing the connections the IP-BUS lead is marked by the red square.
The cable looks like this -->
and you can buy it here ->LINK<-
Jun 25, 2008 | Pioneer Car Audio & Video
Cannot play my portable audio device with Sony cdx c500x
It will only accept audio from the bus in conections when a multi changer is connected and selected.
This is how I connect my mp3 player to my sony.
Swap multichanger audio outputs at the rear of the stereo for my mp3 player, press source to select multichanger.
Remember as I said, if there is not a control cable connected to your multichanger it wont wotk!
Aug 17, 2007 | Sony CDX-C5000X
Focal BUS 25 - 10" Subwoofer with Amplifier Logo
20 people viewed this question
Top Focal Car Audio & Video Experts
xxxxxx xxx
Are you a Focal Car Audio and Video Expert? Answer questions, earn points and help others
