Question about Yamaha NX-U10 Computer Speakers
My YamahaNX-U10 usb port's sound track(?) does not working
When use the usb port , it will connect the electric power to the NX-U10, but NO SOUND!
  • 5 more comments
  • cjchang8 Jan 28, 2009
    When using the USB jack to connect the Yamaha NX-U10, it suppose to have the sound come through the unit. It used to work well. But now it only bus the power to NXU10 but NO SOUND.(I have tried this unit both on Window XP and Mac OSx 10.5, so it should not be the problem of USB driver.) However, using a stero mini plug cable to the Portable jack is fine, there were sound through this unit. What is wrong with the USB jack? How to fix it?
    When using the USB jack to connect the Yamaha NX-U10, it suppose to have the sound come through the unit. It used to work well. But now it only bus the power to NXU10 but NO SOUND.(I have tried this unit both on Window XP and Mac OSx 10.5, so it should not be the problem of USB driver.) However, using a stereo mini plug cable to the Portable jack is fine, there were sound through this unit. What is wrong with the USB jack? How to fix it?
    I have tried this unit both on Window XP and Mac OSx 10.5, so it should not be the problem of USB driver. I actually have a Sonny Vaio with Window XP and a iMac with OS 10.5.
    There is no battery or external power adapter's problem. Powere supply is not a problem.
    It works tthe same with different usb device.
    It works the same with different usb device.
    I did not quite understand what were the technical despict about the USB cable.
    The first USB cable I was using come with the unit. I did try many USB cables since the problem came out.
  • cjchang8 Jan 31, 2009
    The first usb cable was coming with the unit. It worked fine for a while, then broblem started. I have changed servral usb cables to see if it was the cable's problem. But the problem were the same with different usb device.
    Brigadier General:
  • 3,614 Answers
can please be more specific about your problem. kindly input some add info.
Posted on Jan 28, 2009
  • micromaster
    micromaster Jan 28, 2009
    theres a 3.5 mm audio jack, be sure you have one, and check for any damaged on the wire,
  • micromaster
    1. check also the volume control / increase the volume.
    2. install the usb driver again.
    3. set the audio device to :
    for
    • Windows - USB Audio DAC
    • MacintoshMac DAC
  • Yamaha Master
  • 19,396 Answers
This are usb speakers,
Unplug usb port and reinstall software with device unplugged.
Posted on Jan 31, 2009
    Sergeant:
  • 221 Answers
Its definately a problem with the port connection on the internal board.many a time the port gets loosened up on the board causing such a problem.just check out the port internally.and solder it firm on the board connect points.it will get it back working.thanks please do rate the solution.
  • 679 Answers
the problem seems like the usb port have some internal wireing problem.
or there is sure some driver is missing.
tell me that the usb port is works with another usb device or not?
    Scholar:
  • 40 Answers
This problem is associated with the USB drivers not being installed. I recommend reinstalling the device drivers and attempting to output sound.
I've found the manual online for you--> http://www.yamaha.co.jp/manual/english/result.php
In the search field type "NX-U10". Then click on the file to view the manual.
I hope this helps. Please let me know if you have any questions.
Thank You, Raph30
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A most likely issue is that you would have to enable the audio port to use the Yamaha NX-U10 and not the built-in sound card of your computer.
Pls post back your OS and your PC's brand/model.
Good luck and thank you for using FixYa.
  • 2 more comments
  • Louie  Role
    Louie Role Jan 28, 2009
    Alternately, you can use the audio line-in ( mini-phone stereo 3.5 mm) of the NX-U10 and connect to the green jack of your computer .
    If still no sound, then it may be the drivers of the sound device of your computer that needs looking into.
  • Louie  Role
    Have you checked the batteries and/or the external
    Power adapter?
  • Louie  Role
    or replace the USB cable?
  • Louie  Role
    A USB connector/cable would only have 4 wires; +5, GND, Data+ & Data-. Since the unit powers on using the USB's +5 VDC, then presumably the GND is also good. That would leave you with the 2 center wires for Data +/-. Any electronic checks then would be limited to the cable carrying these 2 wires and/or the circuitry they would lead to.
How do I connect my CAD GXL2200 mic to my apple laptop?
You need a USB interface such as an M-Audio M-Track and a standard XLR male to female audio cable.
You use the cable to connect the microphone to the interface using the XLR cable, then you plug the USB cable on the interface to a USB port on your laptop. Finally, you go to System Preferences - Sound - Input and select the USB interface as the input source.
Depending on the software you you use for recording sound (I use Sound Studio from Felt Tip Software) you may need to go into the Preferences for the program and select the USB interface.
Dec 25, 2013 | CAD Microphones GXL2200 Professional...
I get a high pitched noise when in pro tools
I don't know what devices are connected to your audio input ports, sounds like gain is too high on a microphone or guitar or speaker setting too close to your work station, sound like feedback loop.
Nov 02, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
Gaps and noises in my Session recording
Is it bus powered? If it is only plugged into the USB port and not also into the AC outlet, it may be because your USB port does not supply enough voltage or enough current. USB is spec'd at 5V, 500mA, but many fall short. I have the same problem with a Tascam US-122. I haven't tested yet, because it doesnt have an external power port. I would need to splice 5V power into the USB cable.
May 25, 2010 | M-Audio Audiophile USB Audio and MIDI...
Can't make webcam work on Acer Travelmate 4500
This sounds like a USB issue. Not all USB ports on laptops are created equal (they should be but they are not) some usb ports supply enough voltage and current to run usb items properly and some dont. It is always better to run direct from the computer / laptops ports .
If you cant do this then use a HUB but make sure the HUB HAS IT"S OWN POWER SUPPLY !
Also make sure you always use the same port and swapping them around does not always work for all hardware.
Aug 09, 2009 | Microsoft LifeCam NX-3000 Personal Web...
I have Hp Compaq nx 6110 Laptop everything is ok boot system normal no any error but just laptop move any where then system stuck and only way of power off and second problem is "power surge on hub port: a...
1st prob. - I appears there is a loose connection problem somewhere - try reseating your RAN and hard disk.
Try to determine which part of the laptop is causing the problem, not moving the laptop around the room but by flexing different parts of the laptop and power cable etc. while it is on your table.
2nd prob -
Some USB devices draw more power than the USB port can provide and you get the error message - "exceeded power limit".
In these cases you will need to purchase a powered USB hub, connect this hub to the laptops USB port and connect the offending USB device into the powered USB hub.
Mar 31, 2009 | Compaq NX6110 TFT XGA Notebook
Hello, i am trying to get microsoft web cam nx 3000 to work on my vista 32 bit OS however the driver does not install properly, driver error 39. can you help
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 25, 2009 | Microsoft LifeCam NX-3000 Personal Web...
Ms lfecam nx-3000 no pic on mebeam
Normal 0 Probably has corrupt driver.
Jan 03, 2009 | Microsoft LifeCam VX-6000 (68C-00001)...
JVC NX PS1 - No sound output when connected to PC
use the aux in front and connect to headphone output on laptop or desktop
Jul 05, 2008 | JVC NX-PS1 Shelf System
Lacie 80GB
Is this a USB based HDD? It may not be getting enough power.
I have a LaCie 100GB HDD that has 2 USB connectors. One is for data and yes, the other is for power. The 2nd connector is needed because some USB ports do not provide enough power by themselves. I have to use both connectors when I plug my drive into a USB 1.1 port. USB 2.0 ports seem to have enough power.
Try connecting your drive into a USB 2.0 port. If you have 2 connectors, try plugging both in. If this doesn't work you may need a replacement power supply or you may need to replace the HDD.
Binary Bob
Nov 25, 2007 | LaCie (301074) 80 GB Hard Drive
Yamaha NX-U10 Computer Speakers Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
