Question about Frigidaire Refrigerators
Mini fridge not running condenser too hot model # NO.FRC445GB
MODEL # no.frc445gb
SOURCE: Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Posted on Aug 26, 2009
  • 159 Answers
SOURCE: frezer not freezin fridge not cooling
try to change the clickson and relay on the compressor and if it still doing that there are two problems to look for or a blokage in the system or the compressor are broken
Posted on May 16, 2009
jumptrout51
  • 3361 Answers
SOURCE: Coil fan will not run.
Replace the master control circuit board on the rear of the fridge.
Posted on Jun 22, 2009
Sea Breeze
  • 4654 Answers
SOURCE: my mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
Posted on Aug 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: Magic Chef Compact Mini Fridge Model
Might just be the compressor relay. They had a bunch of them go bad in recent years. I have repair photos HERE
Posted on Jan 10, 2010
New Hisence fridge freezer noisy and hot
for the noise check the compressor groumits
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
the reason the outer side of the door seal area is getting hot is the compressor is over heating, probably the condenser fan motor to your compressor is bad.
It should be a little warm but not hot. they don't use heaters anymore ( some older models still use heaters) around the doors, instead they use the condenser coils to remove condensation and moister, you might want to check your condenser coils on the bottom or back of fridge to see if they need cleaning
If the condenser coils/condenser fan are all plugged up they need cleaning and/or the condenser may fail or has failed..
The ones that use an electric heater will have an "energy saver" switch that will turn it off.: God is the reason I give you free advice so God is good!
Dec 24, 2016 | Refrigerators
My daughter bought back a mini amana fridge it seems too hot on the sides and its on 6 os that normal??
Sorry but I don't recognise the fridge brand. The internet suggests these are not the things called mini fridges but in reality are merely coolers so I guess it is a regular fridge designed to keep stuff between 2 and five degrees C.
Not sure what you mean by 6 os.
Conventional fridge design has a thing at the back that looks like a radiator. This condenser is prone to corrosion and is easily damaged resulting in the loss of refrigerant. Since it was decided all types of refrigerant gas is damaging to our atmosphere, manufacturers have been increasingly burying the radiator thing in the fridge casing where it is protected, often at the sides. Usually the condenser will become quite hot until the fridge interior is down to the required temperature when just maintaining the inside temperature it will vary between warm and cold if the door isn't opened much and the insulation and door seal is in good condition.
Burying the condenser(s) in the casing makes them less efficient at losing heat and so they will become hotter than the conventional old-fashioned design during the interior cooling stage..
I hope this helps and little.
May 15, 2016 | Amana Refrigerators
Last week told we needed new evaporator. 2nd guy: it was not the evap replaced the tubing, had 2 ob leaks. recharged, fridge worked and then heated up again. notice door center edge is hot.
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
Dec 20, 2015 | Maytag Refrigerators
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Oct 18, 2013 | Maytag MZD2766GES Side by Side...
I have kelvinator fridge it doesn't cool in both compartment we replaced the compressor il coold down for only 3dayes then returned back to hot state
is the condenser fan running back there?also did you clean out the condenser coil?usually when the middle strip gets hot the coil is filled with dust or the fan where the compressor is isn't running.the condenser fan keeps the compressor cool and all the heat from the machine escapes out through the condenser coil.check this,also the start device could be bad on the compressor,send model number next time you write so whoever helps you can look up your machine.hope this info helps you out.
Sep 15, 2012 | Kelvinator Refrigerators
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
I have an Estate side by side fridge, and the front of the wall dividing the fridge from the freezer is very hot...almost too hot to touch. Any suggestions?
Hi and welcome to FixYa. I am Kelly.
This is s sure sign that either the condenser fan is not running OR that the condenser in the bottom rear of your refrigerator is plugged up with lint and or pet hair. Remove the fiberboard cover from the lower back of your refrigerator and clean the condenser and the condensor fan area.
Just unplug the unit while doing this and be careful not to bend any lines.
If you need parts information or more assistance I will need your model number.
Thanks for Choosing FixYa.
Kelly
Oct 04, 2010 | Whirlpool Refrigerators
Ge mini fridge seems to be overheating
the unit should have heat coming off the condenser coils on the back. some of the units have a little fan motor to help cool the condenser. make sure there is plenty of space for air flow around the unit, as this is crucial to normal operation.
Aug 25, 2009 | Sanyo SR-4911M Compact Refrigerator
Always defrosting GE Model 20
clean the condenser coils at the back and make sure the condenser fan by compressor is running if is not running you mightg need to call a tech to trouble shoot it or if you want repl both the motor and main board like i said you might need a tech to trouble shoot it
Oct 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
Hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Nov 18, 2007 | Refrigerators
Refrigerators Logo
257 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
