Question about Migali Refrigerators
Migali ca516 need parts
Coil on comp. bad
I HAVE A 27 INCH MIGALI SAND PREP TABLE I WAS WONDERING IF YOU SELL A FLAT LID FOR IT INSTEAD OF THE RAISED LID
perhaps you need to ask this on the proper website as we sell nothing here on FIXYA
Feb 18, 2015 | Migali Refrigerators
What would cause a 2003 chevy impala's coil pack to break down?
did u reset the computer after changing coil pack - I was told anytime you put a new electrical part on newer cars the comp has to be reset otherwise the comp don't know that a new part has been installed!!
Aug 10, 2014 | 2003 Chevrolet Impala
I have an older Migali commercial reach in cooler. Label is worn . cannot get the model number. how can I identify for parts?
Generally all of the parts for the reach in coolers are generic. Best thing to do is bring the fan motor into the wholeslaler and match it up. If you need other parts just pull them out and match them up at the wholesaler. I don't remember the last time I was able to find an eom part. If it is a door gasket, you need to use the guide at the wholesaler and measure the length, they will make one up for you. If it is a compresser, there should be a model number on it the wholesaler can use, generally if it has a cold pack on it it will be a AEA4440YXA or AEA4430YXA. Good luck
Sep 06, 2012 | Migali Refrigerators
Car not firing. new sensors, new fuel pump, new fuel reg., car ran great, strong. now if you take a spark plug wire away from coil to check for a spark, none. even changewd knock sensor.
do you have any codes is there communication between comp and scanner if not bad comp what happened to cause this amount of parts being replaced
Feb 09, 2011 | 1995 Chevrolet Camaro
I have a migali fridge model#r28t. The handle is loose and I see no way of tightening it. The back is completely sealed. How can I tighten it?
either get some no more nails glue or some liquid metal and mix it up and follow the instructions on th pack...failing that you might be able to drill it and use pop rivets,you dont ned reare accessfor these.
Oct 13, 2010 | Migali Imperial R28ATH Commercial...
Freezes up under fans
check the temp. control if it is on the right settings,dirty coil,one or more fans not going if all of the above ok short of gas or blockage
Jun 27, 2009 | Migali Refrigerated Prep Table Three...
A 5 ton condensor 12 year old drawing about 33.3 amps it's tripping 40 AMP RATED BREAKER. i't cooling kind of o.k. when it works blowing a temp of about 58 degrees with 95 ambient.
33 amps sounds high, try amping out the compressor by itself then compare to nameplate FLA for it. Make sure the condenser (outdoor) coil is clean, between the fins too, and make sure your fan is running ok while comp is on. Sounds like the bearings in the compressor are giving you problems, A high amp draw on the comp will tell you that. If the comp bearings are bad, you should check your charge, make sure your filter, indoor coil and fan blades are clean, those being dirty can cause a situation where liquid refrigerant gets into the comp, causing big problems.. If you do find the comp bad, I suggest you get a new one lined up before you are stuck in a hot house.
Good Luck
Jun 12, 2009 | Goodman PHKJ048-1 Air Conditioner
Freezer not working
Either relay is bad on compressor or comp is bad. Comp may be under mfr wty; relay is not. Only way to tell is to buy new relay and see if comp starts.
Nov 28, 2008 | Kenmore Refrigerators
Refrigerators Logo
47 people viewed this question
Top Migali Refrigerators Experts
binev_78
Level 1 Expert
Ilia Bichin
ray gallant
Are you a Migali Refrigerator Expert? Answer questions, earn points and help others
