Question about Canon PIXMA MP160 All-In-One InkJet Printer
Fault Code E27
Hi, Can you please help. I have the fault code E27. I am technically capable of repairing the fault but dont know how. I have cleaned the waste tank, as I suspect this was the problem, how do I now cancel the error.
Thanks
Dave
  • Dave Faddel Jan 29, 2009
    The problem is displayed on the printer itself, not on the computer. When you switch the printer on, it goes through the boot up sequence of carrage comming out, going to the left etc. When this sequence is complete it goes into a fault mode with the on/off and yellow error LED's flashing and then displaying an "E;2;7" flashing on the display. It makes no difference if the computer is connected or not. I have had this before and ended up throwing the printer away. The printer is in perfect condition and after getting the error code I stripped the entire unit, cleaned the waste tank and absorber "sponges" etc. The unit is as clean as any new unit, I just need to know how to cancel the fault. How come it only happens on Canon and Epson. HP just prints, no hassels.
  • 3 Answers
Solution that WORKED!!!
NEW REDACTION!!
pineworks Rank: Guru canon.gif computers_small.png Expert Rating: 87%, 1202 votes Hi there Canon printers MP 160 AND MAYBE OTHERS A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
B) E27 - it is code for reset absorber (EEPROM reset or Waste ink counter reset) and follow the described below procedure: With the printer powered off but connected to a power source,
1) First..while pressing and holding the Stop/ Reset button, press the Power button..do not release the Power button
2) Wait till the Power light is ON, then while still pressing the Power button... press the Stop/Reset button two times (visible for alert-orange-LED lights on & off).
3) When releasing both the Power button and the Stop / Reset button (regardless of order), the printer will move into the service mode. Waiting for menu selection visible for:
  1. On/off light is fixed green
  2. Display shows "0"
  3. A4/Plain paper light is fixed green
4) Being in this Service mode, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.
  • Each time the Stop/Reset button is pressed, the 2 LEDs (A4<>Alert) switch alternately into orange and green, starting with orange.(Note: press 4 times for waste ink counter reset).
The number of Reset button pressing:
  1. 1 time Orange Service pattern print
  2. 2 times Green EEPROM print
  3. 3 times Orange EEPROM reset
  4. 4 times Green Waste ink counter reset
  5. 5) Turn off the printer.( it must be turned off) then turn it on again.
Only in B) case you can enter into "service mode", in A) case if have e.g. paper jam, or another error you CAN'T enter the "service mode" Try it
THANKS..JUST GREAT!!!
Posted on Apr 01, 2010
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Can anyone let me no wat the code p1435 means on the dashboard with the engine management light on colour amber please
Susan, 01435 - Brake Pressure Sensor 1 - Electrical Fault in Circuit. Your vehicle will have to be fixed or reprogrammed by a capable technician. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://wiki.ross-tech.com/wiki/index.php/01435
http://www.vwaudiforum.co.uk/forum/showthread.php/125450-A3-01435-Brake-Pressure-Sensor-1-(G201)-Fault-and-others
http://www.audizine.com/forum/showthread.php/569585-ABS-ESP-light-gives-01435-code-Brake-Pressure-sensor-intermittent
http://forums.vwvortex.com/showthread.php?3300683-Brake-Pressure-Sensor-Fault-Code
Mar 10, 2016 | Cars & Trucks
Reset volvo codes
After you repair the fault causing the code you will need a scan tool capable of erasing the fault code. If it keeps coming back after that you have not repaired the problem. There is no other way to clear the code except a scan tool
Jul 12, 2014 | 2004 Volvo S40
How to find Honda CBR 1000 RR Fireblade fault codes
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Help with fault code blinks
Honda Motorcycles Fault Codes Motorcycle Manuals PDF
2004 2005 CBR1000RR Fireblade Repair Manual Download Manuals Technical
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR1000RR Fireblade Owner Manual
Apr 18, 2014 | Honda CBR 1000 RR Fireblade Motorcycles
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
How to fix error code 19 on honda civic dx 1993 5 speed
Error code 19 on a Honda civic refers to AT lock up system malfunction causes ---Lock up control system. Have the code item repaired first and the second fault may be fixed also.
Apr 20, 2013 | Honda Cars & Trucks
Fault code list for Jaguar XK8
Hi there:
I suggest visit this LINK about Jaguar fault codes.
Hope helps.
Feb 27, 2013 | 1999 Jaguar XK8
P0463 and P0499 both codes refer to half circuit high. I keep hearing about good trip equal to zero? have no clue what that means.
Code P0463 refers to the fuel gauge sending unit circuit and P0499 refers to the Canister Purge Solenoid circuit - two totally different circuits.
The reference to "good trip equal to zero" requires the use of a scanner that is capable of reading the data stream from the various Circuits. Many inexpensive scanners are really only "code readers" and will output only the fault codes. They cannot provide you with much of the information required to properly diagnose and repair the problem.
The way a circuit is diagnosed changes completely if the problem is an intermittant problem and is not occuring at the time the circuit is being tested. The data stream will give the fault code and tell you how many trips the vehicle has made without the failure reoccuring. For example, if the circuit failed three trips ago and worked on the next three trips, the good trip count will be "3". If the good trip count is "0" this means that the circuit is failing right now. The troubleshooting charts will send you to different steps depending on whether the fault is current or whether it is an intermittant fault.
There is a lot of misconception in the general public about what fault codes actually do. A lot of people think that you simply plug in the "Magic Box" and it tells you exactly what is wrong with the car and what parts to replace. If anyone finds one of those please let me know...I WANT ONE!!!
What fault codes actually do is give an indication that one of the circuits or systems that are monitored by the computer is malfunctioning. They NEVER tell you what parts to replace. It is up to the person making the repairs to diagnose the malfunctioning circuit or system to determine if any "parts" are actually even needed. Many codes can be fixed by making a simple wiring repair (like cleaning a connector) without replacing any parts.
Dec 05, 2010 | 2006 Chrysler Sebring
Code reader fault 16706
you need the engine speed sensor. Ask the vendor where the exact location is. This is a foreign Car code.Volks wagon. Looked up the code and somebody else had the problem.
Jan 07, 2009 | 2001 Volkswagen Passat
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
129 people viewed this question
old marine
old marine
