Question about Canon PowerShot SD100 / IXUS II Digital Camera
Works sometimes other times not
Will work perfectly sometimes but will not take photos or video at other times - there is a black or distorted diplay when looking at a bright light source. The playback mode works all the time. Can you help?
  • Mike Dell Jul 27, 2007
    Sent camera to Canon for evaluation but do believe this is the solution. Thanks
    Genius:
  • 2,985 Answers
This is CCD problem that Canon know about Get onto customer support- a possible replacement camera is on the cards.
Posted on Jul 24, 2007
SOURCE:
After some homework, I am thinking perhaps the problem is the T-CON board? Do you think that is likely the problem?
Hello... No, it a Main board. If the T CON was the cause, all video would be affected, including the menus. This is not a guess... I work on TVs for a living, and have seen this symptom several times. It's always the Main board. I hope this helps!
Nov 26, 2017 | LG Televison & Video
Why does my acer aspire laptop have a black screen?
This could be a failing hard drive or failing RAM. The easiest and cheapest fix is the RAM. replace your RAM with some new sticks. It is easy and a lot cheaper than a hard drive with Operating System re-install. Which could also mean a loss of personal data (photos and videos) When your computer is working, back up your personal data as soon as you are able.
May 24, 2013 | Acer Aspire 5350 5750 5750g 5750z Series...
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
Jun 27, 2011 | Sony STR-DE605 Receiver
I have the above model camcorder ,the playback on my laptop with windows vista is terribly poor jumping all the time/distorted with jvc software provided or on windows media player it plays but audio is...
Are you playing the video directly form the hard disk in the camcorder or are you transferring the file to the laptop first? Reading high volumes of data via USB is slow and the PC may not be able to read the data fast enough from the camcorder. Try copying the video to the laptop first, then play it back.
Feb 20, 2011 | JVC Everio GZHD500 High Definition AVCHD...
I am using the Epson Perfection V700 photo scanner to scan dental xrays. Sometimes the xrays come out perfect, other times I get streaks across the image. Sometimes the streaks are colored, othertimes...
You have to use the "FILM AREA GUIDE" included with the scanner. This black plastic guide leaves a small area at the top of the glass open so that the scanner can calibrate itself at the start of each scan. Use the guide or leave at least 8mm between the top of your film and the top of the scanner glass.
Jan 24, 2011 | Epson Perfection V700 PHOTO Flatbed...
Blank black screen
CCD FAILURE!
Call OLYMPUS for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
Kindly Rate me WELL !
this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
Good Luck !
May 29, 2009 | Olympus FE-270 Digital Camera
All Hdmi sound distorted
You have a bad HDMI Cable.
-Captain Jake
Feb 13, 2009 | Sony Playstation 3 (PS3) Console
VIDEO DISTORTION
check some of your wirings.. make sure nothing is peeled off and touching any metal OR buy a car voltage regulator.
Apr 29, 2008 | Car Audio & Video
Taking photos or video works sometimes
Hi, I think this is problem due to LCD Diplay. Sangita
Jul 23, 2007 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD100 / IXUS II Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
