Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Setting bluetooth on a Epson stylus SX600FW
I would like to connect my printer with my laptop using the bluetooth printer port but i can't get to activate bluetooth on the printer.
When you go to the bluetooth parameters in the printer menu i can only define the pin but not go down in the menu to the bluetooth connection.
Can you help??
  • Anonymous May 16, 2009
    Can't set my bluetooth on sx600 to my mobile phone. Any advise welcome.
  • Epson Master
  • 1,879 Answers
The bluetooth dongle for your printer is sold separately. call epson store to get one.
Posted on Jan 28, 2009
  • 30 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-26
Posted on Sep 04, 2009
No manual for sx600fw unable to set and use printer fully
How do I clear a cartridge jam in my 924 dell printer? Please help.
May 02, 2010 | Epson Stylus CX6000 All-In-One InkJet...
EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 29, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Laptop running vista will not print wirelessly
check the cable connections, unplug replug the cable.......then turn it on
Sep 09, 2009 | Epson Stylus Multifunction Inkjet Printer/...
INSTALLATION OF EPSON SX600FW
http://support.epson-europe.com/onlineguides/en/sx600series/html_z/p03.htm
this is the web site that explains how to connect to the network. i hope this helps.
please rate good.
Mar 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Connectivity of printer with newer computers
does ur unit have The LPT connection or COM ports .
u can use this ports as a alternative connection.
also check for MAC converter cables!!
plz rate this post as good as u can
Feb 06, 2009 | Epson Stylus Color 3000 InkJet Printer
Connecting wi-fi on Epson SX600FW
I hada the same problem. I used the settings on the actual printer rather than through the software to input the information it needed and It works fine now. I was able to set it up on my husbands laptop without any problems, I just added his laptop through installing the software on his laptops as it had picked up the signal and was showing in the Network and sharing centre on Windows Vista premium. Hope this helps. I think you need to take the wire out now and now load it as wireless. You need to use the wire first to connect then take it out to connect to the wirelss network. My router is a Sky router.
Tiptap
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Connecting to printer via Bluetooth but driver is missing
using the bluetooth software on your computer, do not tell the computer you are looking for a bluetooth printer, instead, use search for all devices, then the printer will show-up and select it.
printing via bluetooth does not require a driver (it's just like printing from your cellphone)
Dec 27, 2008 | Zebra QL 420 Thermal Label Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
2,470 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
