Question about Dryers
My daughter has an Amana dryer. When the dryer is on the timer doesn't move, it will run for about four minutes and during that time before it turns off it will get loud. It doesn't turn on for about 20 minutes, after it turns off and we try to start it, it just buzzes. Inside the dryer it get too hot.
  • gallegos_jmg Jan 29, 2009
    Thanks MNfisherman. That's what I was thinking but not sure.
  • 11,896 Answers
Timer needs to be replaced
Posted on Jan 28, 2009
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Dryer tumbler for a short time then shuts off,will not run a full cycle like it stuck
see this causes and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and needs replacing. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace the Heating Element.
Sep 27, 2012 | Amana ALG331RAW Gas Dryer
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
Heating but not drying, doesnt seem to be blowing very strong through dryer vent
Hi cipera11...
I think your problem is a clogged or cogging vent
Heating Element
Cycling thermostat
Please take time to rate me thumbs up.
Sep 11, 2011 | Amana Dryers
Amana lga30aw. dryer starts in auto mode, pilot on, gas on, goes off after awhile and never comes back on. timer does not move in auto but does move on the timed mode (still does not dry in the timed...
You may need to replace the timer, but watch the video below and it will walk you thru the troubleshooting process. The timer not moving in the "auto sense" mode maybe due to a bad thermostat. Here is a link to the timer in case you need it.
Jan 05, 2011 | Amana ALG331RAW Gas Dryer
Timer dial gets stuck on Amana dryer.
The only fix is to replace the timer.
Aug 30, 2009 | Amana Dryers
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
My Amana Model NDG5800AWW dryer has ceased to dry clothes dependably. The Only setting that still sort of works is HIGH timed drying, and this heats up to what used to be the "delicate" setting....
if you are using the auto dry setting and the dryer is still running after 5 hours you either have a timer issue or a thermostat problem.
The timer is driven by a motor, if the timer motor is bad the timer wont time out.
in the auto dry cycle the thermostat has to cycle off and on which then sends power to the timer again advancing the timer.
set the timer in a timed dry cycle for say ten minutes, if the timer advances and turns off then you know the timer works. if it doesnt advance you have a timer motor issue,
if the problem is the auto cycle, you could replace the thermostat, about $20 american. however a clock timer would be cheaper.
Based on how old is your machine and do you want to stick a timer in it after already paying the service man is up to you.
A basic bath towel load should be dry in about 50 minutes, this varies on how good your seals are and how long a vent you are running, if the dryer vent was plugged you already have shortened the life of your heating element.
Sep 22, 2008 | Amana Dryers
Dryers Logo
63 people viewed this question
Top Dryers Experts
