I have a magnavox mwr20v6 I dubbed vcr to dvd without a PROBLEM, TO NOW, HAVE HOME MOVIE ON VCR, TRIED TO DUB TO DVD, AND IT WILL START AND RUN FOR FEW SECONDS AND A MESSAGE COMES UP SAYING IT IS ILLI
TRYING TO DUB VCR HOME MOVIE FROM MY CAMCORDER, TO DVD, RUNS FOR A FEW SECONDS AND SAYS IT IS ILLIGAL TO COPY THE VCR, tRIED EVERY THING i KNOW, BUT DOES NOT HELP, TRIED SEVERAL DIFFERT HOME MOVIES, SAME RESULT, i HAVE DUBBED THEM BEFORE, BUT NOT ANYMORE.
meee7779
  • 15 Answers
SOURCE: VHS to DVD - D-VR4XSU
have u tried the seting on the vcr, you know how u can change the lenght of recording on the vhs
Posted on Mar 29, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Dubbed DVDs will not play
You have to use the Magnavox dual to finalize the discs, and then they should be able to play on other players. I don't have a manual for that exact recorder, but in general you would go to the Settings Menu of the DVD player --> go to Disc Edit --> and then select Finalize - the exact pathway might be a bit different on that particular recorder. Once you have finalized one of your discs, try it on another DVD player and see if it works. Good luck!
-Tha Mp3 Doctor
Posted on Feb 15, 2009
SOURCE: Dub VHS to DVD
I am not sure why the DVD recorder is stopping after 25 mins of recording. However, once a disk is finalized all the remaining space is unrecordable. That is why your computer is showing the disk as full. The same applies when finalizing a CD. As for the first problem, check to see what record speed you are using. XP is 1 hr, SP 2hr and so on. But stopping after 25 minutes is weird. Even if you use a quick record button, (aka OTR) the recording is usually done in 30 minute increments. Try it again. If it still is only recording for 25 minutes, you may want to contact the manufacture's customer service or tech support. Hope it helps.
Posted on Mar 30, 2009
SOURCE: VCR DVD Recorder not dubbing
I called the manufacturer and realized I was using the wrong type of recordable DVD disc to dub to. Non copy protected VHS tapes dub just fine as long as I'm using the proper disc.
Posted on Jun 05, 2009
complexity
  • 3 Answers
SOURCE: I have a Magnavox ZV427MG9. I follow all
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Posted on Aug 23, 2009
Recorder will not dub
What are you trying to dub, a movie on original dvd or something you recorded from tv. Some cable systems send an anti-copy signal with pay movie channels and can be almost impossible to copy. There are ways but no easy unless you are experienced. Same with purchased movies on DVD. See DVDfab program for ways to do that.
Dec 08, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
Dubbing VHS to DVD With Magnavox
If you are trying to dub a commercial (pre-recorded) tape it will not work. If this is not what you are trying to do, get back to us.
Jun 07, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I'm trying to dub old vcr tapes to dvd and need a way to get around the tape's copy protection system. Help?
Strangely enough, the tape protection is more effective than the current dvd protection because it was analog. The tape is encoded with "bleeders" that distort the picture should you try to record it. You might be able to get a separate VCR and plug it into the dvd "in" as a work around. Also, you can buy used dvds of your favorite movies from Amazon for a few bucks each. Save yourself the time and headache and poor quality of that dubbing process.
Aug 19, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do we dub VHS to DVD without remote?
Fisrt, is it set up already to dub. It willnoe finallize if not. If so then just put a blank dvd in, push dubbing, insert tape, check source to make sure it is going to dvd then push dubbing again
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Jun 03, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Wont dub from vcr to dvd
Saw your request this morning.
Take note, sometimes our email alert system to we experts does not notifiy us about requests or questions you may pose later regarding this post of yours.
What patch cables, if any are you using now for audio? If there are ports on the back for audio out and audio in for DVD? Currently, are you using the internal circuitry to dub over to DVD from VCR?
Regards,
Worldvet
Jun 29, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Mar 29, 2008 | Philips Magnavox DVD/VCR Dual Player
Want to dub
Protected tapes cannot be copied to DVD on this machine.
The only way is to connect the VCR to a separate DVD recorder with a special cable to remove the Macrovision protection.
These cables were readily available on the internet, but I have no more details.
Mar 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
