Question about Lexmark F4270 Plain Paper Inkjet Fax
Printer i,m having a problem installing the printer correctly.
  • 139 Answers
Hello Shoolmom Need more Info,are you using a usb Plug Do ypo have software,What operating system are you running? Im live on line now If you want answers ttech
Posted on Jul 24, 2007
My cannon lbp3200 printer couldn't install driver on win7
hello hasanmehdisk
here is a link to a driver page, please select the appropriate driver for your Operating system, as well as the correct language. uninstall any drivers that have been installed, unplug the printer, and install correct driver. Follow on screen instructions, plug printer in when instructed, or after driver has completed the installation,
Aug 14, 2011 | Canon LBP3200 Laser Printer
After installing printer & drivers printer is still showing an error. Error light is flashing and "sel" button will not remove flashing error. Printer has paper installed correctly, ribbon is...
After installing the printer and the software you must reboot the computer to register the hardware changes. After booting up open your "printers" from the Control Panel or Start "settings - printers".
Make sure that the printer is listed. If it is listed, right click on it and select "properties". Now the printer control panel will come up. Select - "Print test page". If the software and cables are installed correctly the printer will be listed and it will print the test page.
In the same way, with a right click on the printer you can select to make it your "Default" printer.
New operating systems will see the new hardware and offer to install it for you. If you say yes and OK the computer will do an internet search and it should find the correct drivers for your operating system. If it does not find the correct drivers for your operating system you may have to the companies web page and select support - downloads and find your correct driver.
Apr 13, 2011 | Citizen iDP-3550 Receipt Printer PC...
My HP Deskjet 5740 is connected bu it won't print
when you connect your printer make sure the cables are in working order and check that they are connected correctly use your manual that came with the Printer to make sure you are starting it correctly(turning it on correctly) then run the CD-Rom and follow the prompts to install, making sure you download the latest drivers if the ones on the CD that came with ur Printer is no good.
you may have to un install first and reinstall it make sure you take the time it takes to install it correctly first time and no short cuts or this could be your problem. (mostly with printers it is driver problems that prevents them from working correctly.
Jan 02, 2011 | HP DeskJet 5740 InkJet Photo Printer
Printer prints only rows of characters
A few possible reasons:
1. The printer driver is corrupted. Uninstall the printer from the computer and install the driver again.
2. The cable is not correctly connected. Be sure the connection from and to the printer is correct.
3. The printer needs to be setup. Be sure the emulation or printer mode on the printer configuration is correctly indicated.
4. Be sure that you are sending to the correct printer. Perhaps you have more drivers installed on your computer and sending to the wrong one.
Dec 18, 2009 | HP LaserJet 4L Printer
I just purchased a C540, color laser printer. HOWEVER, in setting the printer up, and trying to print anything, the printer won?t print. Nada. Seems as if there is no communication. Everything is plugged...
u have to installed driver first in your PC then after cheak your printer installed correctly go in control pennal open printer option see there there was showing your printer if u have installed correctly then after right click on it then set is as a default printer then try to print
Nov 15, 2009 | Computers & Internet
I can not install driver Printer Canon LBP 2900 on Vista 64bist
it could be possible that you are running on a different platform, say Vista, and you are downloading on XP vice versa, ensure you have the correct version of the driver you wish to install, unless you correctly choose the right OS, you will never make this work. sometime it is confusing really...
hope this helps
Jul 10, 2009 | Canon LASER SHOT LBP-2900 Printer
Printer has connected but offline.
your printer correctly installed to your pc the printer driver I mean did your install it correctly? The usb cables has correctly attach to the CPU and printer? Thier is no broken wires of your usb cable did you try to replaced it with new one usb cable.
Apr 18, 2009 | HP Deskjet 2360 InkJet Printer
I HAVE INSTALLED DOWNLOAD AT LEAST IT SAYS IT IS INSTALLED. BUT IT STILL DOESNTPRINT. IT ALSO SAYS MY INK IS LOW . I JUST INSTALLED 2 NEW INKS.THIS IS ANEW UNIT AND WE HAVE BARELY GOT TO USE IT. I WILL...
do you have the model of lexmark printer ? You need to make sure y ou install the correct driver for the correct OS. try to search you model in below link, it might be helpful for you to get the correct driver...
http://etech.maiila.com
hope this helps
Nov 25, 2008 | Office Equipment & Supplies
My printer will not install
Are you expecting for the disc to be auto run? not sure if you are using the correct disc to install the correct driver on the OS .. you need to make sure this is correct first before installing it.. below link might be hepful to resolve your issue and getting the correct driver
http://etech.maiila.com/canon-pixma-mp210-photo-all-in-one-printer-driver-manual-and-software
good luck
Nov 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Hp 3015 not installing
Problems seem to occur when printer cable is plugged in before software is installed.
Delete driver and software installed, disconnect printer from PC.
Download and install correct driver to suit, connect usb when software prompts to do so
Make sure the driver you are installing is correct for you system
LINK to DRIVER DOWNLOAD
Nov 18, 2007 | HP LaserJet 3015 All-In-One Printer
Lexmark F4270 Plain Paper Inkjet Fax Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
