Simpson front loader model 45S651D i can't open the door. its having trouble finishing cycle now it has i cant open it!
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
  • Deborah Galarza
    Deborah Galarza Aug 13, 2014
    Hello, Will the proceedure you provided work on a Kitchenaid Front-load washer KHWSO1PMT2. We were having issues with washer Start button clicks but not engaging the start mechanism and displaying dL codes. We tightened the screws and the problem more or less went away for a few weeks. Occassionally it would just click without codes. This was usually remedied by unplugging the washer for several hours. Then, it seemed to miraculously correct itself for a week. When we returned from a two week vacation, our first load wouldn't start, just clicked. The door will not unlock.
  • Deborah Galarza
    When researching a remedy, we saw a video show how to use fishing line to partially encircle the door throught the space where it locks, pull the latch around the door and it opens. This looks like it could be a bad idea. Your thoughts? Thank you, ALL of you, for contributing your expertise.
I have 5.5 kg front loader simpson EZI sensor washing machine,the handle to open the washine machine has gone loose and now can not open my full load of washing from the machine
you need to take the top off turn off the mains supply
and reach down to the door catch behind and manualy open it
if the handle has cracked a the pivot pehaps a flat blate screwdrive and you can carefully release it
youll find a littl preasure to the door will help you then let go and the door will open easier
Mar 02, 2015 | Simpson Washing Machines
Can not open the door on my front loader hoover electra 530
Please check on this link for tips to release the lock: click LOCK
Jan 17, 2013 | Washing Machines
I have the Kenmore energy star front load washer, can't get the model number because I can't get the door open. How can I get the door to open after the wash cycle has finished?
most kenmore front loaders have either a door below the lock or, you can pull out the pedestal then: reach up inside where the lock is and, feel for a lever or, a ring pull the ring down or, the lever over, sorry I can't be more specific but, this info should help.
Jul 26, 2010 | Kenmore 43142 Front Load Washer
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
Hi, I have a "Simpson Espirit 45S651D Front Loader Washing Machine". It doesn't seem to be going through its cycle properly. The clothes come out wet, and it won't spin properly. I put it on the...
Peace Friend,
ngfam1 At your service!
With an error the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!!
If not only a trained laundry tech can make the electronic diagnoses.
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Aug 31, 2008 | Washing Machines
Washing Machines Logo
213 people viewed this question
Top Washing Machines Experts
