Question about Weather King 12AJA4801AH Air Conditioner
Black sticky residue in gas furnace vent pipe.
I have a gas furnace on my upstairs floor that vents up through the roof. Last winter the sound of the furnace igniting started getting louder and louder (scary booming sound). It would try multiple times to ignite and sometimes shutoff and try again a few minutes later. Noticed that the vent pipe had sticky blackish/brown residue leaking down inside the pipe and would then leak to the outside of the pipe. Heating guy came out, cleaned pipes, furnace, internal fan, and replaced the igniter. We were okay for about a month and then the same problem started again. Heating guy came out AGAIN and said he was stumped -- he'd never seen anything like it. It was the middle of winter and the roof was covered with snow (unsafe to get on the roof for further exploration), so he cleaned it and said to call him in the spring or summer. Again, the cleaning lasted for about a month and we were back to square one again. We had to shut off the upstairs furnace for the rest of the winter. Considering we paid the heating guy $300 for no solution, we decided to try and fix it ourselves in the summer.
During the summer we discovered rust in the vent pipe -- it was galvanized metal. Thinking the metal was defective or something (and the black sticky stuff was melted rust), we replaced the entire vent pipe with new galvanized metal and cleaned the furnace again. This winter the furnace has run for 3 months and the booming and ignition problem have started again. We are going to have the shut off the furnace again soon if we don't find a solution. PLEASE, does anyone know what this black sticky residue problem could be? and what we can do to fix it?
  • Danny Clark
    Danny Clark May 11, 2010
    Did you also replace the pipe on the outside, on the roof including the vent cap?
    Novelist:
    Champion:
  • 230 Answers
Unless this is some weird act of G-d, like sap from a nearby tree or something I will stick to furnace facts. LOL. Anyway, this sounds like an incomplete combustion situation. Let me explain. During the combustion process many elements are necessary to facilitate "complete combustion". If the correct combination is not met, the result will be a blackish residue. If you combine this residue with the condensation that normally occurs in the flu system, it could turn muddy or sludgy. This is can be a dangerous situation due to the amount of carbon monoxide (poison gas) nessessary to create this residue (similar to the film in the tailpipe of your car).
I would suggest calling another reputable company that offers true "combustion analysis" reports. The test takes around 30 minutes and they should be able to confirm my diagnosis. This test should cost anywhere between 100 and 200.00(US). Many times a simple adjustment to the gas valve or burner assembly will due the trick. Best of luck!
Posted on Jan 28, 2009
Rotten eggs smell
The smell is sewer gas coming back in the house from the sewer or septic tank ether from a dried out water trap in a floor or fixture drain, or from the roof vent, or a hole or separation in pipe or fitting. Like wax ring under toilet. First pore water down every drain to fill any trap that might have gone dry, then flush toilet or run washer or drain bath tub.This will displace gas in pipe and will cause the smell to increases if there is no smell then the problem is fixed if not check roof vent it may need a charcoal filter on top, There is no water trap on air vent on roof and is an open hole to the sewer or septic, The heating system in the winter or AC in summer will draw the gas inside from the vent.If it is the vent you should be able to smell it from outside. If all tests fails You will need to have a smoke test done. A smoker is set up outside and the line is filled with smoke and will show where gas is coming from. Also it might be a good ideal to check all gas fittings in case it is a gas leak.
Jun 15, 2014 | Plumbing
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
Toilet BLUBS downstairs when flushed upstairs.
Your sewer vent may be clogged, or if you are in the northern climates, frosted shut. When you flush the toilet the water displaces the air in the drain piping. The vent gives the air somewhere to go. If the vent is plugged the dispaced air forces it's way out through the path of least resistance( the lower toilet in this case).Pour some hot water down the vent where it comes through the roof to thaw it out.or run a snake down the vent. Hope this helps.
Jan 01, 2014 | Home
Cracked Selkirk METALBESTOS gas vent pipe on 80% efficiency furnace (Trane XE80)
I would check with a local furnace company that installs Tranes and ask if they sell to the public, if so buy it.
Oct 12, 2012 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
Cast iron boiler pipes not heating
IT sounds like the pump if this a wet sytem the expaisin tank could be dry
Feb 02, 2010 | Heating & Cooling
Should the vent pipe be hot
If it is a single wall vent pipe and it goes into a masonary chimney that
has double wall pipe, you can expect the temperature to be over 120deg.
If it is double wall vent pipe all the way to the roof, I would say that
the pipe might be under 100 deg. I guess I would have to no what type
of vent config you have.
If you think that it is way hotter than you can recall in the past, if it has a induced draft blower, make sure it is operating. You could take the vent connection apart at the furnace and make sure it is not plugged.
If you have a water heater tied in with the furnace vent. You could take
a lighter or a match and put the flame near the water heater vent, if it
blows out than you have a problem with your vent system.
Things that could cause this is another fan operating, a gas or wood
burning stove or an attic fan. Could also be due to the chimney vent
not being above the roof line and on a windy day could cause
backdraft.
Jan 17, 2010 | Goodman Heating & Cooling
Have Mansfield #160 and hear a fog horn like sound when flushing toilet. What can I do to fix?
Are your wast water pipes in your house vented through the roof? If they are maybe the vent pipe is clogged. At my father in-laws house the pipes are not vented through the roof like their supposed to be to vent sewer gas. they are not vented at all. Every time you flush it sounds like someone is downs stairs screaming. Something to do with air/ suction in the pipes.
Sep 05, 2009 | Mansfield Plumbing Products Mansfield...
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Condensation running down old vent pipe running to roof.
This is a condensing furnace and is ment to condense. You will need to pipe away the condensate using a hose and maybe a condensation pump. It is unclear where the combustion air pipe is going? Are you using room air? or do you have a second pipe going up the old vent as well?
Jan 05, 2009 | Goodman GMS90703BXA Heater
Weather King 12AJA4801AH Air Conditioner Logo
1,000 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
