Question about Epson PictureMate (C11C556001) InkJet Photo Printer
Epson picturemate deluxe I installed a new ink cartridge but the screen says there is no cartridge.
  • 826 Answers
It can be various reasons like..
Didn't remove protective tape on cartridge.
Didn't properly seat cartridge.
Contacts on carriage need to be cleaned.
You can clean them by cleaning the contacts on the old "empty" cartridges, then installing/removing them a few times.
**If you need any kind of technical assistance you can contact support cell at here
Posted on Jan 24, 2013
SOURCE: Epson rx580 printer
I just started calling Epson's customer service line every time. They always offered to FEDEX new ink. I got tired of waiting for it to come and began returning bad cartridges to office depot where I had bought it and found out that they will take it back if it doesn't work. Now I've decided that some (a lot) of Epson's ink cartridges for the RX580 are bad and that I just have to keep trying until I get ink cartridges that work. I had tried the qtip cleaning, checking the ink/sensor connection, and making sure I had them snapped in tight. I've finally figured out it IS the ink. BTW, I always use the ink Epson reccomends, so it is definately that many of their cartridges are faulty. It's a pain to have to return them but as long as I can return and replace them and eventually have a machine that will print when I need it to, I can live with that.
Posted on Mar 12, 2008
Basti
  • 1447 Answers
SOURCE: Code:P error message: Pad saturated.. ink leaked..replace cartridge
Hi!!
Chances are the printer needs maintenance, you can actually send it to a repair center to replace the inkpads for your printer, try this link for information and you can download as well the utility from this site after registering:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Your printer has a one year warranty if its still within the warranty call epson if not try this site www.epson.com/loyalty and try the passcode minute or market and register. Hope this help. pls dont forget to rate solution. Thanks!!
Posted on Apr 19, 2008
Tirzo
  • 94 Answers
SOURCE: Epson CX6900F - The Magenta
It appears to be that your printer is malfunctioning and require service. Please call Epson for your warranty verification or you may want to send your printer to nearest service center in your area.
Posted on Aug 14, 2009
CaptainHawk1
  • 345 Answers
SOURCE: epson rx595 cannot recognize ink cartridge
Just had this happen to me. Turned it off, turned it back on... nothing. In/out with the cartridge several times and when I blew on the contacts of the printer (where the little microchio on the cartridge touches) it finally worked. Did the blowing on the contacts help? Maybe, but more likely is that the it was just repeatedly trying to d oit before the machine figured it out.
Posted on Sep 26, 2009
arjoy
  • 87 Answers
SOURCE: My Epson 105 doesn't recognize my Epson 88 ink cartridges
please use only recommended cartridges found either on the upper portion of your printer or in the printer manuals.... take note of the code.
Posted on Jan 28, 2010
Changed cartridge, received a code "P", says to install a new cartridge, but I just did install. Will not allow to do a clean print head.
hi, first turn the printer off and unplug it and let set for 30 mins. Ig that doesn't work try taking the cartridge out and reaching inside where you put the cartridges go and clean the print head with alcohol with a q-tip.
Nov 22, 2015 | Epson Picturemate Picture Mate Deluxe 500...
Can anyone help me with a Code:P on a Epson PrinterMate Deluxe 500 with a Print Pack T5570? OK so while trying to clean the print heads many times it gives me a Code:P and says to replace the cartridg
Hi
My main thought is why do you need to clean the print head so much, because on nearly all Epson machines I have come across actually use up ink during the cleaning process and if you clean the head too often you empty the cartridges, which are not exactly huge capacity in the first place, very quickly. The circuit board/chip on the cartridge records the amount of ink used, and a lot of cleaning may run one of the colours out. I give below a link to the Epson site which has a number of links about your printer which may help. I found the Product Information Guide quite good, especially the last few pages which referred to the head cleaning.
Epson PictureMate Deluxe Viewer Edition Compact Photo Printer
I have also found the following company very good for inks, both original and compatible. (Having seen the price of Epson original cartridges I'm not surprised you are a little miffed about their lack of longevity!!!
Epson PictureMate Ink Cartridges Genuine Compatible
Hope this helps
Nov 07, 2014 | Office Equipment & Supplies
reload,shut off and turn back on several times till it fids that it has been replaced!
Jan 24, 2013 | Epson PictureMate (C11C618001) Deluxe...
I installed a new ink cartridge but the screen says there is no cartridge or it is not installed properly or is not recognized.
I have the same issue. It does not matter if there is a new cartridge, an old cartridge, a reset chip cartridge in the printer, it just gives the same error message.
Jun 18, 2010 | Epson PictureMate (C11C556001) InkJet...
Ink cartridge shows error
replace cartridge, some times the cartridge dries out fast
Dec 07, 2009 | Epson PictureMate Photo Printer
Even with a new cartridge it says empty cartridge and won't print
are you using a generic ink cartridge? and just for added information, picturemate cartridges or so some epson inks do have expiration dates, pls check because if you have them stored for quite sometime the tendency is that the inks will harden up. then it will not distribute ink to your nozzle.
another thing troubleshooting steps, have you tried to perform a cleaning cycle? try to do it for about 4 or 5 times. then try to print. pls be advised that it will take in a certain amount of inks to clear the cloggs and force it out.
or before installation of the cartridge, did you shake them? for about 5 times then insert it back
Sep 27, 2009 | Epson PictureMate 500 InkJet Photo Printer
Hello! I don't use my Epson PictureMate as often
That is a problem with the Ink jet printers. Lack of use causes the cartridges/heads, etc. to dry up. You're only solution (I'm afraid) is to replace them.
TIP: If you're typically not using the printer for several days or even week(s) at a time, it never hurts to print a single (low coverage) page of colour every few days just to keep the ink flowing
Jul 10, 2009 | Epson PictureMate C11C623001 Photo Printer
Hi!!
Apr 19, 2008 | Epson PictureMate (C11C556001) InkJet...
Epson PictureMate (C11C556001) InkJet Photo Printer Logo
221 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
