Question about Verizon Communications Verizon Wireless G'zOne Cellular Phone
There has been an error in processing your call, please power down and turn off your phone. Then turn your phone back on and try your call again.
Phone locked up while trying to install update.
hold power button until you can power down. then power back up
Mar 22, 2015 | Apple iPhone 5
My pandigital has a box pop up that says "Sorry" The process android.process.acore has stopped unexpectedly. Please try again. Force close." It just keeps popping up and won't let me do anything....
Try holding down the power and volume up buttons down for several seconds to try and soft reset your device. Power down and restart it. You don't state your model of Pandigital-that makes it hard to determine exact reset procedure. Also look for a small hole on the back or sides of the device, into which you can push a toothpick or paper clip to push a reset button (check your manual for location and reset procedure for your device). You can also try powering down, then press the volume down button and while holding that down, press the power button to turn the device back on. The error indicates a major problem with the base android software - did you recently upgrade software or install some new app? If it was a new app, try uninstalling it and see if the problem goes away.
Jan 02, 2015 | PANDIGITAL Novel Color Multimedia eReader
HTC wont turn on
HTCs have a known power glitch that affects many of their model of phones. Unplug the phone. Hold down volume down, volume up and power. Do not let go. Plug in power. Hold those three buttons down for NO LESS THAN three minutes. You may see a flashing red light in the process. Once you see solid red, it is in a charging state. Allow it to charge for an hour or so and then attempt to power it up normally. You may want to get a quality replacement battery from eBay or a respected vendor, since chances are you other battery is toast. Li-Ion batteries don't like to sit in a drianed state for very long without loosing their mojo.
Mar 17, 2014 | Cell Phones
Have error code fffffe70 on nokia lumia 520
try hard reset of the phone.. it resolve the issue 100%
following are the steps
To reset your phone:
  1. Tap About, and then tap Reset your phone.
  2. You'll receive two warnings. If you're absolutely sure you want to restore your phone to its factory settings, tap Yes, and then tap Yes again. (It might take a while for the process to complete.)
  1. Turn off your phone.
  2. Turn on your phone again by pressing the volume down button until you see the exclamation mark2787168.png
  3. Then, reset the phone by pressing the following four buttons in this order: Volume up, Volume down, Power, Volume down.
  4. Your phone should now reset and restart itself. (It might take a while for the process to complete.)
Dec 26, 2013 | Nokia Lumia 520 Windows Phone Black
Lg p500 screen frozen
Hi
Have you tried removing the Cell battery and re-inserting it again?
Then try performing a hard reset of your device.This restores factory/original settings on your phone BUT deletes all user data and third party applications.This process also deletes system errors on your device.
  • Press and hold Power + Home + Down Volume key for five seconds.
  • The device will turn on and perform the reset.
Hope it helps.Thanks!
Ken.
Mar 24, 2012 | LG P500 Cell Phone
How do i get rid of error message "the application Open House (process android.process.acore) has stopped unexpectedly. Please try again."
It happens when the process is manfuctioned or corrupted. I advise to do a factory reset. To do so, turn off the phone, holdon the home button and press the power button. It will go to recovery console, now select "Wipe to factory setting", once finished, turn off the phone and restart. It should take care of the issue.
Thanks and regards,
Anil.B.R
Oct 11, 2010 | T-Mobile G1 Android HTC Google Smartphone...
please try to reset its because of the software corruption it usually happens in Htc models...
1.Phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
2. Wait for the phone to finish the reset process and then press MENU.
if it does not solve upgrade to latest firmware
Update to latest version
http://www.htc.com/www/support.aspx
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | HTC G1
No service error
this is caused by a curruption in the software you can try to uninstall any apps that where added when the error started or reset the device
Apr 01, 2010 | HTC Hero Smartphone
I can't turn on my phone
hi thanks for using fixya!!
What is the error?? Try to remove the battery then install it back again, then try to turn on again the power. Please observe the error again.
Regards!
Jun 01, 2009 | LG Vu CU920 Cellular Phone
Verizon Communications Verizon Wireless G'zOne Cellular Phone Logo
515 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
