Question about Verizon Communications Verizon Wireless G'zOne Cellular Phone
What's your problem?There has been an error in processing your call, please power down and turn off your phone. Then turn your phone back on and try your call again.
My pandigital has a box pop up that says "Sorry" The process android.process.acore has stopped unexpectedly. Please try again. Force close." It just keeps popping up and won't let me do anything....
Try holding down the power and volume up buttons down for several seconds to try and soft reset your device. Power down and restart it. You don't state your model of Pandigital-that makes it hard to determine exact reset procedure. Also look for a small hole on the back or sides of the device, into which you can push a toothpick or paper clip to push a reset button (check your manual for location and reset procedure for your device). You can also try powering down, then press the volume down button and while holding that down, press the power button to turn the device back on. The error indicates a major problem with the base android software - did you recently upgrade software or install some new app? If it was a new app, try uninstalling it and see if the problem goes away.
Jan 02, 2015 | PANDIGITAL Novel Color Multimedia eReader
Have error code fffffe70 on nokia lumia 520
try hard reset of the phone.. it resolve the issue 100%
following are the steps
To reset your phone:
  1. Tap About, and then tap Reset your phone.
  2. You'll receive two warnings. If you're absolutely sure you want to restore your phone to its factory settings, tap Yes, and then tap Yes again. (It might take a while for the process to complete.)
  1. Turn off your phone.
  2. Turn on your phone again by pressing the volume down button until you see the exclamation mark2787168.png
  3. Then, reset the phone by pressing the following four buttons in this order: Volume up, Volume down, Power, Volume down.
  4. Your phone should now reset and restart itself. (It might take a while for the process to complete.)
Dec 26, 2013 | Nokia Lumia 520 Windows Phone Black
I was updating my iphone 4s and decided to turn it off in the process of updating as the internet connection was too slow. When i tried to turn it back on, it just wouldn't load. What should i do?
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 31, 2012 | Apple iPhone 4S
Its sayn error in connection
Try powering down your phone, then turning it back on. If this does not work, try posting your phone's model number and carrier information so that we have a better idea of your problem!
Sep 23, 2012 | Cell Phones
Htc inspire 4g stuck on lock screen and won't unlock
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your HTC Inspire 4G is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and hold the Power button until the device turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
Aug 29, 2012 | HTC Inspire 4G Smartphone
Phone keeps turning off and messages won't open.
hypagirl, your device has a software error, so you need to hard reset (by code or keypad) or soft reset or factory settings (by device settings), if your device is samsung try *2767*3855# for full reset, and if is nokia try *#7370# and default code is 12345, this both process will delete all data so first make a back up.Best of Luck. if my answer was helpful please rate it.
Jul 18, 2012 | Cell Phones
Reset
If you want to apply a soft reset, i.e., thus keeping all your data and installed applications, press and hold the power button, until a context menu comes up, and tap 'Power off'. Wait for it to turn off, and press and hold the power button again, until you see the Motorola logo screen. It will come back to life restarted. An alternative way, useful in case your phone is stucked in some odd state, is to remove and re-insert the battery pack.
On the other hand, if you want to hard reset your phone, i.e. restore it to its factory defaults, thus loosing everything you have installed, as well as your personal data, if your phone is operational, go to 'Menu > Settings > Privacy > Factory data reset'. There is a checkbox to optionally clear of your SD card as well. Then, tap 'Reset phone'. On the other hand, if your phone is stuck (i.e. not operational), proceed as if you were soft resetting it, but, when it starts the process, i.e. as soon as you see the Motorola logo, Press and keep holding the volume down (-) key, until you see an exclamation mark. Then, press both the volume down (-) and up (+) keys. The Motorola boot menu screen will come up. Selection of an item is made through either the volume up or down keys, and selection is through the power button. Select 'Recovery -->', then '[Custom Recovery]' and 'wipe data/factory reset'. You will be prompted to select that action again, listed between a lot of 'No's. Afer the wipe is done, select 'reboot system now'.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if Ican assist you any further.
Regards, Carlos
Sep 18, 2011 | Motorola Mobility Defy Cell Phone
My phone won't start, when you press the power button it tries starting then when it gets to the windows phone screen it restarts. Please help.
PLease do a hard reset ... Here is how you do it .
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Press Vol down for reset .
Thumps up if this works ..:-)
Aug 09, 2011 | HTC HD7 Cell Phone
My htc surround (windows 7 phone) wont turn back on if i hold the power button on it loads up to the white htc screen and stays on i tried taking the battery out to reboot it self but that didn't wrk...
PLease do a hard reset on the phone and here is how you do it .
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Aug 04, 2011 | HTC 7 Surround Cell Phone
Verizon Communications Verizon Wireless G'zOne Cellular Phone Logo
356 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
