Question about LG Studioworks 700S 17" CRT Monitor
To adjust the shape of the screen
Need proper osd adjust like how much at tilt and all description
  • Anonymous Apr 16, 2009
    this reset thing doesnt work for me becouse it returns to previous state. i cant because i changed my shape zise position more than once. is there any other way to reset monitor menu configurations to its default?
Reset the monitor configuration.
go to the menu and find reset of recall setting option.
Posted on Jan 28, 2009
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
Lcd monitor working fine but the adjustment screen apears on my monitor in a small square enveloppe how can i restore system thanks in advanceDewulf Jan
I assume by "adjustment screen" you mean the OSD (On Screen Display). This is the box where the menus for adjusting the screen appear. If I'm correct, that means you have pushed the "menu" button on your LCD and need to push it again to turn the OSD off. If pushing it again does not solve the problem I would say it's time to have the LCD repaired. In many, but not all, that OSD goes off on it's own after a bit.
Mar 01, 2014 | Relisys TL565 15" LCD Monitor
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
Dec 07, 2010 | Dell Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE:
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
I can't see the whole screen on the monitor - I have a W1943T - how do I adjust the width?
This page has manuals and drivers for your monitor:
The manual explains how to use the buttons on the monitor itself to make adjustments. A description of this "on screen display" (OSD) starts on page A10 of this manual. Page A14 shows you how to move the image vertically or horizontally.
You may need to adjust the resolution. Higher resolutions will make the images on your screen smaller, so more likely to "fit."
Also, if you are just using generic drivers, you may see some improvement by installing the correct drivers that are specific to your monitor.
Feb 06, 2010 | LG Computers & Internet
OSD on m onitor
sounds like bad capacitors on the power pack, is this an older monitor ? could use some more info on age and type of monitors and the video card used.
OSD is On Screen Display and it is for adjusting screen functions like color brightness etc.
different screen resolutions can cause a monitor to shut down.
Apr 04, 2009 | Acer Computers & Internet
There are buttons on the front of the monitor. Why
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
Jan 27, 2009 | Acer X193W LCD Monitor
Sony KV27FS120 Tilt correction
Use the tilt adjustment in the menu system or if that doesn't go far enough, move the metallic object, (loudspeaker etc) further away from the screen.
Jul 26, 2017 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Shape of LG Monitor
What are actual value for all the shape properties? it is already in owenr's manual.
May 04, 2007 | LG Flatron 776FM 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
184 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
