Question about Hitachi Televison & Video
Show me how lopty look like in ceronic monitor chassis
Lg tv ct -29q47e out of focus and no picture on all av inputs
Try LG support toll free number: 800 243 0000. I hope this helps. Thank you and please leave feedback Lincoln. I am a new 6ya fixya agent.
Jul 14, 2016 | LG Televison & Video
Golden tee black screen
Are you able to advise some more detail for this issue please?
Can you play the game 'blind', which means coin it up, start a game and hear the game making normal gameplay sounds? If so this shows there is an issue with the monitor, or the wiring to the monitor.
Are there any lights lit up on the main game board inside the cabinet? If so this also shows there is an issue with the monitor, or the wiring to the monitor.
Is there any neck glow on the monitor tube, which is the back of the tube itself where it narrows down like a funnel to a narrow glass tube? If so this would indicate the monitor is most likely functioning and could be a game board issue.
You can also determine whether a monitor is functioning by turning up the brightness to full using the brightness potentiometer on the monitor chassis, or the potentiometer on the flyback transformer. The flyback transformer is the plastic looking device that the high tension lead comes out of and connects to the monitor tube, a lot like a spark plug lead connects from the cars distributor cap or coil pack to the spark plugs. It should show a lighter screen and probably with lines in it if the monitor is running.
Jan 24, 2014 | Arcade Golden Tee Unplugged Video Cabinet
Tv not switching on Sansui SV2918, replaced faulty PTC and trans D2449 for lopty switching
all the transistors ,& capacitors i.e 47mfd 63v or100mfd 63v must be changed before u on the tv. if 300v is not coming to middle pin of d2449 then 4.7ohm resistor(fusible) may be gone
Mar 24, 2010 | Televison & Video
It has blue and green arc colors showing up with duplicate words at the lowest part of the screen-just showed up yesterday It is a Pioneer Elite projection monitor receiver PRO-710HD
Replace Both of Your STK ICs They are Big Black ICs will have STK392-110 on them upgrade ICs to 120s-150s,or 180s Call Mat Electronics for parts
1-800-628-1118 ICs will be on the Left hand side of Chassis Mounted on The very First board,there are screws holding board on Fame/ board also plugs in bottom of chassis.
Jan 21, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Looking for part: LOPTY no BSC26-01N4010C or BSC26-01N4010AP
Yes we have in stock this transformers orignales BSC26-01N4010C or BSC26-01N4010AP
May 29, 2009 | Hitachi Televison & Video
Dell E193FPC
Looks like your inverter board is broken.
Similar problem as Neovo F-417 (same chassis) , Look for 715L1283-4 inverter board
Try http://lcdpartsandrepair.com/e193fpc-inverter-power.html
Jun 26, 2008 | Dell E193FPC 19" TFT LCD Flat Panel...
Error 162 there is not actulization of the bios
To find your BIOS upgrade you can do one of the following options:
1.Identify your Intel motherboard model via our Award BIOS or AMI BIOS id's tabs
2.Find a(n) Intel BIOS upgrade via the Links tab on the official site.
3.Run the BIOS Agent scan browser plugin
Jun 13, 2008 | Computers & Internet
42 Ilo plasma tv
Sounds like a blown lopti. Tech job.
Mar 02, 2008 | Tatung P42BSKT 42 in. HD-Ready Plasma...
Televison & Video Logo
27 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
