Question about Intel 1U RM S3200 SR1530SH 8GB DDR2 2BAY SATA LGA775 PCIE8GBE2 1333MHZ Motherboard
Hi....! Iam using Intel945GCNL Essential Series Mother Board for my Desktop.. I had 1 GB DDR2 RAM 800MHz.. I bought another 2 GB DDR2 RAM 800 MHZ and installed on my Machine.. ! Will this affect my Desktop in future ? Since i reffered Intel site the expandable is upto 2 GB RAM...! Do i have to remove the RAM ? But iam in need of 4GB RAM ? Iam using Core2 Duo Processor 2.4GHz. Thanks and Regards karthik
  • qaseh Jan 28, 2009
    i want driver for motherboard gigabyte ga-m61sme-s2
Posted on Jan 28, 2009
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
Jul 16, 2011 | Computers & Internet
Im plannin 2 upgrade my RAM..My mother board(Essential series D102Ggc2) supports DDR2 processor is Pentium D 820+ query is: DDR2 800 is supported by Mother board but is it supported by my...
Your motherboard has the follwing memory support : DDR2 533/400 SDRAM 2 slots, Single-channel (2GB2 Max). As long as it is supported by your motherboard there would be no problem since your processor is also supported by the motherboard.
Please refer to the follwoing links from Intel:
Mar 06, 2011 | Intel Pentium D 820 Smithfield 800MHz FSB...
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
I want to upgrade my system ram size to system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Does intel desktop board d945gccr support DDR2 Ram 667 or 800 MHz
intel d945gccr supports ddr2 400 mhz & 533 mhz it maximum support ram is 2gb
Nov 22, 2009 | Intel D945GCCR Motherboard
Maxing memory speed, GB or MHz more important?
I don't think a difference of 133MHz of memory speed will make a difference in your gaming performance either way. Also, you won't be able to use more than 3.5GB of memory if you don't have a 64-bit operating system. Finally, it'll be a rare person who actually notices a difference in using 8GB vs 4GB of RAM. So, in conclusion, just buy 4GB of 800MHz RAM and spend your money and your time on a good graphics card, if gaming performance is your main concern. If you have any further questions, contact me through
Nov 03, 2009 | Intel Motherboard
My system won't boot after installing a new 2 GB DDR2 RAM
Try cleaning it edge connector with soft eraser both side and dont try to touch the pin. If it doesn't help you got a defective one.
Apr 28, 2009 | ASUS M2N-MX Motherboard
This motherboard only support DDR type of RAM up to 4GIG , 400 MHz • 333 MHz this are the support speed of DDR RAM, so you can go ahead upgrade up to 4 GIG of RAM and that will make your computer very fast...
Nov 04, 2008 | ASUS GeForce® 4 V9180SE MX 440, AGP...
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Intel 1U RM S3200 SR1530SH 8GB DDR2 2BAY SATA LGA775 PCIE8GBE2 1333MHZ Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
