Question about Radio Communications
Itek 158007
Instruction manual
Itek jukebox plays for maybe a minute or 2 then dies.
Locate the main amp since it does it on all functions. It will be on a big heat sink. Chances are it's a single IC type possibly marked STK. See image below. If it is I would replace it.
May 22, 2016 | Audio Players & Recorders
Instruction manual
Instruction Manuals ' Singer Sewing
www.singerco.com/support/instruction-manuals
Our replacement instruction manuals are provided in a downloadable PDF file ... To download a manual, you will need to know your machine's model number.
www.singerco.com/accessories/instruction-manuals
Narrow Your Results: Find accessories for your specific sewing machine: Currently Viewing: Sorry, no results were found. ^ Back to top of page. Products ...
Downloadable Sewing Machine Manuals - Ismacs
Nov 29, 2015 | Sewing Machines
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Itek jukebox
The CD drive will need to be replaced, no way around it.
Dec 23, 2013 | Lands Phones
Itek 15003
Contact the maker or talk to someone in another shop hope this helps
ddmac19
Oct 25, 2013 | Cameras
Looking for an operating manual for a Itek platemaker 617s?
I have an itek platemaker 617s and when I turn it on I get a resetting message in the upper right corner of screen, Most of the time I have to play with it by turning it off and on several times until it clears or other times it does not clear and I can't do anything with it, then I have to leave it off for hours and that does not always fix the problem.
Any one know anything about this problem, everyone I have talked to does not have a clue.
Oct 09, 2010 | Cameras
Yardman lawn tractor, w/ twin B&S 24 hp Itek after ran for a while mowing I shut the deck off it will not reengage
Check the belt, it may have come off the pulley, or may have oil on it. Make sure that when you move the PTO lever that the pulley on the bottom is also moving so that it tiughtens the belt
Jun 10, 2009 | Mtd Garden
Sound card's driver CD lost
You have already solved your problem. log onto the cards mfgr. web site and go to the downloads section. they will ask make and model. drivers from mfgr are free.
good luck!
Oct 01, 2008 | Car Audio & Video
Radio Communications Logo
44 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
