Question about Toshiba MD13M1 13 in. TV/DVD Combo
Does my toshiba model have a digital tuner?
Do I need a converter box with the change from analog?
  • 57 Answers
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Posted on Feb 11, 2009
  • SIMONE DARRINGTON Feb 11, 2009
    To clarify: No, Your Toshiba does not have a digital turner. Yes, you will need a converter box. I hope this solution is helpful. Please take a moment to rate this soluton.
Is my toshiba CF35E50 a digital tv
This TV only has an analog tuner. You will need a set top box (digital to analog converter) to watch OTA TV.
I hope this helps.
Mar 22, 2011 | Toshiba Televison & Video
Will the Toshiba Model 36A42 work without a converter box?
The short answer is no. The reason for that is because it's an analog TV and has a standard tuner which is now obsolete because of the changes to all digital programming last year. You won't be able to use it with out a converter box. I won't recommend a particular brand or model, that would be your choice. Here is a selection of "boxes" available.
http://www.google.com/products?client=firefox-a&rls=org.mozilla:en-US:official&channel=s&hl=en&q=Digital+to+analog+converter+boxes.&um=1&ie=UTF-8&ei=GVSxS9WXE4-CswPd27XKAQ&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CC8QrQQwAg
Mar 30, 2010 | Toshiba 36A42 36" TV
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
We have a Toshiba HDTV model number 57H82. It is
Sounds like a bad tuner/decoder on the Qam analog side of things. You can bypass this with a Clear qam converter box or a analog to digital tuner box or simply having this repaired upwards of $200 bucks.
Thanks for using Fixya.com
You're Toshiba Tv Expert.
Aug 31, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba Color TV CF306 - Can it receive digital, with converter
The short answer is yes. The method is to set the TV to receive either channel 3 or 4. The converter will receive the digital broadcasts and "re-broadcast" them on either 3 or 4 analog for the TV to receive.
Let me know if you need anything else.
Dan
Mar 14, 2009 | Toshiba Televison & Video
Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Dan
Jan 28, 2009 | Hitachi 57G500 57" TV
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
Is converted box necessary for Toshiba 27D46 tv
The Toshiba 27D46 has a digital tuner, so you should be good to go when the switch to digital occurs.
Dec 18, 2008 | Toshiba 27D46 27" TV
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Toshiba MD13M1 13 in. TV/DVD Combo Logo
1,722 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
