Question about HP Pavilion DV4015cl Notebook
I have an dv6000 the internet connection is not responding, I m using a router , what can be the problem
  • 1 more comment
  • mrs_beads200 Jan 28, 2009
    To tell the truth I don't know what kind of router I have, I don't know that much about routers :(((( this is the first time that I'm using one. I don't think it's wireless , I believe it's a modem also....by the way I have windows vista, do u think that if I use XP will solve the problem ?
    PS : how do I know if it's the NIC card ?
    thanks a lot.
  • Jaime Arboleda
    Jaime Arboleda May 11, 2010
    Is this computer that you have a New one, I think it is unledd you upgraded an old one to Vista, but if it is, it might be the Router, where did you get the Router from was it given to you by the ISP ( Internet Service Provider ) or is it your own, you might want to see if you ISP provides one for you and they should be able to go to your house and get you connected, in most cases it is the router but in other cases its Windows Vista's security. ( too secure for its own good ).
  • Jaime Arboleda
    Is this routter a modem also, or are you connecting a modem to the router?, and is this a wireless router? and are you connecting this to the wireless part of the router? have you tried to connect the PC to the modem directly to see if it works? it might also be the NIC card.
  • 21 Answers
Look to see if your wireless switch is turned on
Posted on Feb 28, 2009
Ihave a dv6000 laptop and and it has a 1394 net adapter but i can't connect to internet what must i do to connect
The 1394 Net adapter that you see in the Device Manager is simply the Firewire Controller....similar to the USB controller. It is not the same as WIFI or have anything to do with Internet connections...UNLESS you obtain a Firewire network adapter dongle and install it. Then you can connect to the Internet in the same manner as WIFI. The dv6000 DOES have WIFI, as well as a 10.100 Fast Ethernet cable connection that can be used to connect to the Internet.
Mar 18, 2015 | Internet Computers & Internet
DNS server not responding on WRT54GL Linksys router
You are looking for DHCP server. It provides the IPs addresses for devices to connect. DNS resolves the IP into a name. Not really required unless you are setting up a virtual server, or the special setup.
Feb 12, 2013 | Linksys Wireless-G WRT54GL Router
I get messages that Internet is not responding ??
1. Please check the DNS is present in your router or not.
2. Please check your router is connected to internet cable.
3. Please check your internet cable is connected to your router's internet port only.
4. please check your compuetr is geting IP address or not
Mar 13, 2010 | NetGear WGT624 Wireless Router
My WRT54GC won't let me into the control panel. I've looked up the solutions for hours, and i can't get it to work. I'm using a MBP and a HP Pavillion dv6000, and it's the same with both of them. If i...
If you connect the router (WRT54GC) to your broadband modem does it then allow wireless action? Your router has an Internet address. It is 192.168.1.1, in all probability. Check your manual to be sure. Access to the control panel is through this address. You must log in to the router then set up the Wireless, the SSID (the name you give your network) and any security you set up. I prefer the WEP-PSK[TKIP] as it's easiest. Other things with the router, settings and such, pretty much are set automatically, so once security is set you should be good to go. Good luck !!!
Nov 11, 2009 | Linksys WRT54GC Compact Wireless-G...
Cannot connect to internet. Computer sees router. Router does not see internet. can connect without router. How do I reset?
hey same is the problem with me... plz can u help me.. i have bsnl broadband with netgear modem. wen i connect it to pc it works perfectly. but wen i connect the same to lapton. local connection is plugged but internet does not get connected. Error comes something like this.- Remote computer is not responding. plz help me.
Oct 29, 2009 | Linksys Wireless-G WRT54G Router
I cannot connect to the internet when I use the netgear router.
If I am understanding you correctly, you are removing the cable from the modem, then connecting it to the router. This is your first mistake. Once you've completed the connecting wizard on the CD that came with the router, you should take the cable that is connected from your modem to your PC, and disconnect it from the PC and connect it to the "WAN" port on the router. Then take a second CAT5 cable, and connect it to port 1 on the router, then to your PC where the first cable was connected. If this does not solve your issue, please respond.
Mar 30, 2009 | NetGear SUPER-G WGT624 Wireless Router...
Internet connection on laptop
go back to the instructions you used to mess up the router when you tried to connect a psp, and undo them
Jul 14, 2008 | Computers & Internet
Router stops responding with red alert light turned on
Is the actual router not responding or the internet?
(IE - can you still log into the router but the internet won't work, or will it not even connect to the router)
Dec 27, 2007 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
