Fuser paper jam on Dell mono laser mfp 1125
I removed the paper through the door on the back of the printer. Opened the front door where the printer cartridge is and pulled the cartridge out and put it back in. I can't see any paper in the path but I still get a message saying fuser paper jam.
What should I do.
Thanks,
  • Anonymous Apr 01, 2009
    fuser paper jam won't go away... actually making me kind of crazy.
  • richielanduc
    richielanduc Dec 20, 2012
    ADD ME TO THAT; EVEN REINSTALLED PROGRAM. NO PAPER VISIBLE
    Problem Solver:
Please double check if all doors --- including the paper tray cover --- are firmly (repeat FIRMLY !) closed --- seemingly all such are designed as precautionary measures for safety operations.
Posted on May 31, 2009
  • chrisxlii Jan 11, 2011
    There, I fixed it:
    I put a piece of card-stock into the regular paper tray. Then I turned it off and then on again, which tricks it into trying to run the topmost piece of paper (in this case, the card-stock) through the feeder. The card-stock was heavy enough to push the crinkly paper out.
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
Dell Mono Laser MFP 1125 says no toner found invalid toner it just flashes the above i just added a new cartridge
double check the one you installed to ensure it was installed correctly. You can do this by removing it with the power turned off then reinstall it. Try to power it back on.
Spanish speaking available for all problems Thank you for allowing us to help, please respond with further questions and concerns
Jan 09, 2011 | Dell 1125 All-In-One Laser Printer
I have a Dell 3010 that has error msg paper jam fuser 077-104. I cannot find a paper jam anywhere in the printer. I turned it off, unplugged, checked under drum, opened all doors and checked everywhere....
you need to check the fuser, sometimes a small piece of papaer or a label stick on he fuser in order to do this you need to open the back and top cover. or take the printer to service
Aug 21, 2010 | Dell 3010cn Laser Printer
Fuser paper jam
is a stuked paper sensor, or misplaced, check more carefully
Jul 15, 2010 | Dell Office Equipment & Supplies
Dell Laser MFP 1815 won't print. Message keeps coming up Jam 2 open rear and front door. Have opened and shut doors repeatedly, restarted printer, tried copying over message but it keeps being displayed....
I had same problem. If you go to rear of printer and open the back door you'll see it is attached to a blue connector. Unattached it so that the door opens fully and then unflap the inside roller assembly. Next open the fuser door and you'll notice a little spring loaded assembly on the inside of the opened fuser door. This is where my problem was. Make sure that the assembly springs back when pushed because part communicates with a sensor on the motherboard. If it doesn't spring back then the printer thinks there is a jam. Mine was stuck but after pushing it a few times it started to work freely again. This was a frustrating problem but that fixed my issue and hopefully it will fix yours.
Jun 04, 2009 | Dell 1815dn All-In-One Laser Printer
Dell laser printer MFP 1125 paper tray removal
I just did this 5 min ago. The tabs that hold it on the machine have cams that hold it in. just squeeze the tray lightly at the tabs and it slides right out.
May 31, 2009 | Dell 1125 All-In-One Laser Printer
Paper is torn at fuser area of Dell 1125 and cannot remove
Please double check if all doors, including the paper tray cover, are firmly (repeat FIRMLY !) closed. Seemingly all such are designed as precautionary measures for safe operation.
Mar 08, 2009 | Dell 1125 All-In-One Laser Printer
Laserjet 4345 mfp paper jam
13.20.00 can be also caused be a jam near the fuser (the part of the printer that gets hot to make the toner stick to the paper). Remove the toner cartridge and take a look for small scraps of paper along the whole path. Also open the door on the back of the printer and look for paper scraps from there. If you see paper stuck in the fuser, do not use anything sharp to remove it, be careful not to scratch the surfaces.
Oct 08, 2008 | HP LaserJet M4345 MultiFunction Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
2,295 people viewed this question
k24674
