Question about Minolta DiALTA Di520 Laser Printer
Di520 missing 24VDC - are schematics available for PU1?
My copier has a 0070 error and in investigating I find that the DC power supply appears to be missing one 24VDC line that runs M21 and others. I am hoping that the schematics are available for this PCB, but the download that I have found does not contain that particular one.
  • Minolta Master
  • 1,297 Answers
Change Sub Hopper Toner Replenishing Motor.It is the tipical malfunctions,the service manual not specificy this problem.This motor is energized for the toner replenishingtime witch is calculated based on the ATDC sensor output voltage T/C ratio and the size of the paper being fed trought the copier.
Posted on Jul 30, 2009
Canon image RUNNER 2520 error is E000110
Failure of the Scanner Motor (M21)
The Scanner Motor (M21) speed lock signal does not indicate a locked state a specific period of time after the Scanner Motor (M21) has been started.
* The same condition is detected after the error retry is performed.
1.Check the cable.
2.Replace the Laser Scanner Unit.
3.Replace the DC Controller PCB (PCB4).
Jan 09, 2018 | Canon Office Equipment & Supplies
What is soulotion canon photocopior error 000110
E110 : Failure of the Scanner Motor (M21)
1.Check the cable.
Nov 11, 2016 | Canon Office Equipment & Supplies
Canon 2525 error 000110 what is soulotion
You will have to do the following:
1.Check the cable. 2.Replace the Laser Scanner Unit. 3.Replace the DC Controller PCB (PCB4).
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
0b000d 00000012
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Oct 11, 2013 | HP DesignJet 1050c plus InkJet Printer
Canon ir 2220 ERROR CODE E261
U NEED TO INVESTIGATE
the input/output ports of the DC controller PCBs.
COPIER>I/O>DC-CON<DC-CON (5/7)>
P020 xxxxxxxxxxxxxxxx=runs from left to right 15>0
ADDRESS=P020
BIT-
0- zero-cross signal -
1- heater trigger 1 signal 0: ON
2- heater trigger 2 signal 0: ON
3- heater error OFF signal 0: error
4- not used
5- not used
6- M9 registration motor phase A pulse signal -
7- M9 registration motor phase B pulse signal -
E261 0000
The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
Are the connectors J205 on the main power supply PCB and the connector
J308B on the DC controller PCB securely connected?
(zero-cross signal: J205-7 <-> J308B-1)
NO: Connect the connectors securely.
2. Main power supply PCB, Main controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Jan 22, 2013 | Office Equipment & Supplies
Error E000 on Canon NP 6317.
IX. SELF DIAGNOSIS The DC controller PCB has a microprocessor that diagnoses the functions of the copier (particularly the sensors) at appropriate intervals. If this microprocessor detects an abnormality, it will display the type of the abnormality on the indicator on the control panel. The table below shows the various fault codes, their meaning, and the corresponding detection timing. Example of E000 code indication: Eó000 light alternately. Fault criteria • If the temperature difference between the thermistors 1 and 2 is 60°C or higher. • If the fixing asssembly temperature is lower than 50°C after 15 sec from the power-on. If the tempereture remains 220°C or higher for 0.1 sec or longer. If warm-up is not over after 60 sec from when the temperature reached 50°C. If fixing unit temperature drops below 50°C when the copier is in stand by or copying. If the C HEAT CHECK signal is on while the HEAT ON signal is off. If the main motor speed feedback signal does not appear after 2 sec from the main motor. If the break signals is generated continuously for 0.1 sec or more when the counter is not being driven. Code displayed Main cause Fixing roller heater (LA1) low temperature error Thermistor1 (TH1), Power supply assembly, Fixing roller heater (LA1), or DC controller PCB Fixing roller heater (LA1) low temperature error: Thermistor, fixing roller heater, AC driver, power supply assembly, DC controller PCB, thermoswitch (F1), auxiliary thermistor (TH2) Fixing roller heater (LA1) low temperature error: Thermistor (TH1), fixing roller heater, power supply assembly, DC controller PCB, thermoswitch (F1), auxiliary thermistor (TH2) Fixing heater ON timing error: Triac (U104) on power supply assembly Main motor error: Main motor (M1), DC controller PCB Counter (CNT1), DC controller PCB E000 E001 E002 E003 E004 E010 E030
Jan 05, 2010 | Canon Office Equipment & Supplies
24vdc power supply
well, GND, N and L should be mains power lines.
May 22, 2008 | Office Equipment & Supplies
Looking for a power supply
Sorry about the above post, but I wasn't signed in yet and this crazy GLITCH here put me down as a GUEST instead. The above post was mine, as I'm resending it again below.
Thx,
Frank
FRANK'S FIX IT SHOP
AC/DC power adapter + Power cord. 24VDC power adapter + power cord for Toshiba 20HLV15 20" Flat Panel LCD TV
Specification:
Input :100-240VAC (50-60Hz)
Output : 24VDC 4Amp (72W)
Part# ADP-2404-3PX
Approx cost: $50-60
Call Toshiba USA and give them that p/n for an exact cost quote plus shipping.
Best regards,
Frank
Apr 01, 2008 | Toshiba 20HLV15 TV
Error E061 & 0070
grid bias at upeer limit
Dec 19, 2007 | Canon CLC 1120 Color Copier
76 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
