Question about Maytag Neptune MAH6700A Front Load Washer
Maytag washer front load
Make a loud noise like if is touching metal. Could be BEARING broken?
  • 2 more comments
  • gmg12 Jan 28, 2009
    I think the The bearing are worn out or broken because I open the back of the machine and I could see pieces of small metal
    It seem loose all the part of the machine were you load the clothes in and I never overload
    How much would it cost to replace all the part approximately?
    If the sound is consistent/non-stop like a screeching/high-pitch, then yes. This is what it sound like.
    Thank you
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If the sound is consistent/non-stop like a screeching/high-pitch, then yes, it would be the bearing. If however, the sound is more like thumping/rumble, then it would be the tub/drum itself rubbing against the support, bracket or structure. While this indicate an out-of-alignment issue, the bearing could very well also cause the said misalignment. Depending on the number of years in service, some components ten to be rusted or bent. It is also possible for the support brackets/rods/system to have failed.
Initial course of action would be for a look and see by opening the bottom/kick panel and/or the rear. Visual inspection while the tub/drum is manual turned would reveal where the sound is coming from. Thereafter closer inspection would reveal if it is a bearing issue or a support structure problem.
Good luck and thank you for using FixYa.
Posted on Jan 28, 2009
  • Louie  Role
    Louie Role Jan 28, 2009
    If it is a Maytag MAH6700A and you are considering a DIY (do-it-yourself), then replacement parts and exploded diagram are available from here.
  • 11,896 Answers
That is most likely your bottom. as long as your tub isn't running, then your bearing is going out.
  • Nate Stansfield
    Nate Stansfield Jan 28, 2009
    while the tub is turning see if it is off balance while making the screeching sound. If it is moving all around and not staying straight, you bearings are shot and I would suggest having a repair replace it because it is a long time consuming job. I have worked on MANY!
  • 13,433 Answers
The bearing might have worn out or broken.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Washer makes a loud noise on spin cycle
Alright, well, thats when you open the lid, move the clothes around close the lid and walll la. okay having more problems, well get a new washer.
Jul 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer noisy when in spin cycle. also there's a small hole located in the back of the machine on the drum with metal shavings coming out of it. The noise is a loud grinding noise. could...
You have a bad rear bearing in the outer tub. The entire outer tub would need to be replaced to resolve this issue.
Check your owner's manual to see what kind of warranty you have on this part. I'm keeping my fingers crossed for you as this is an expensive repair!
Good luck!!
Jun 16, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Epic Z Washer has object between drum and tub.
did you ever find out how to separate the tub and basket on your maytag washer? I have exactly the same problem.
Jun 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Very loud noise during spin cycle
Probably a broken strut or support. some call it a shock absorber.
May 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Loud spin noise from Maytag washer
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.
Jan 05, 2009 | Washing Machines
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer noise
probably is the bearing will eventualy start leaking from seal
Mar 12, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MAH6700A Front Load Washer Logo
19 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
