Question about RCA DRC6309 9 in. Portable DVD Player with Screen
RCA DRC99731 second screen is blue? why? - RCA DRC6309 9 in. Portable DVD Player with Screen
2 Suggested Answers
g_a_x
SOURCE: Could you please help me
Hi! I have the same! Did you get the way to unlock it? Thanks in advance!
Posted on Nov 26, 2011
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Blue screen rca tv model 14f512t
you will have to take it in to get repaired. might of put a speaker or something megnatic near your tv.
Oct 21, 2012 | RCA 14F512T 14" TV
Could you please help me to unlock (region free) my RCA DRC99731 dvd?thanks
Apr 15, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
My screen went blue and now the unit will onlyl power on for a few seconds and shut down
Very common problem with the ITC222 chassis RCA which is what your model is. The Blue CRT is most likely shorted. You can get a replacement CRT for your model at www.tvrepairworld.com and it also conatins the CD with instructions on how to remove and replace the CRT.
Dec 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue power light is on the tv cant turn it off
Unplug the TV wait 10 Seconds and Plug it back in. Should work fine
Sep 26, 2009 | RCA L42FHD37 42 in. LCD HDTV
Rca D52W20 blue screen when turned on
Almost certainly the blue picture tube is bad. This is a huge job to replace and quite expensive. Generally it is not worth doing.
Mar 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
RCA Scenium HDLP61W151yx1
its the color wheel.
Jun 28, 2008 | Televison & Video
RCA DRC6309 9 in. Portable DVD Player with Screen Logo
35 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
