Question about Generac 14,000 watt Automatic Standby Generator
Check battery Flashing inside panel says check battery
F1 light flashing 9 times why?
Hi Anonymous, it should be noted that the reasons EFI lights constant or flashing, will or will not start, turns over or not conditions varies from the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work or event IE: adding accessories, electrical curiosity/adventures, laying bike down/crashes, rainstorms/bike washings just before EFI light issues started can be significant hints/aids into tracking down the gremlin, also carry the appropriate jumper wire to access fault codes to reduce the risk of being stranded or towed, that being said the usual suspects are:
1. Faulty Fuel Pump, fuse or system relay switch.
2. Battery starting to fail due to old age/damage, perform a load test.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
5. Broken wire or worn insulation exposing wire to a ground situation especially inside wire harness at tight bends around fairing brackets, under dash panels, under fuel tanks over cylinder heads etc. Many harnesses are open on the ends that will allow water to enter and accumulate at v-bends.
Dielectric grease and contact cleaner are your best friends for wire/cable/harness connectors, look for corroded, broken, or loose pins/sockets. Good luck and have a nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 27, 2015 | Motorcycles
How do I reset the flashing system charging light?
you have a shorted diode or internal voltage regulator problem ! Is the check engine light on ? This charging system is computer controlled ! Don't just change it have it checked !
Apr 09, 2015 | 2010 Mazda 6 2.2
No power to car key wont turn
check the alternator and check for a short or ground a wire may be touching the frame you may want to check the engine computer module
Feb 17, 2014 | 2004 Mercedes-Benz S 430
Fridge freezer
HI jACQUELINE.well i reckon the fridges r a bit temperaMENTAL.:).Before u do anything well u can check weather u have ice build up on the rear panel inside freezer compartment.either way i would first turn it off for 24 to 48 hours.then remove bottom plinth panel (bellow the door).thoroughly clean condenser coils right to the end.then try u could get lucky.if it doesnt work then the problem could b inside the panel.def/heater,fan motor,t/stat,or the board.good luck Ali
Aug 24, 2012 | Refrigerators
2009 zuma won't start and the check engine light stay flashing ?
Hi, Sadiesalcedo it should be noted that the reasons your check engine light constant or flashing, will or will not start, turns over or not conditions varies from the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work or event IE: adding accessories, electrical curiosity/adventures, laying bike down/crashes, rainstorms/bike washings just before EFI light issues started can be significant hints/aids into tracking down the gremlin, also carry the appropriate jumper wire to access fault codes to reduce the risk of being stranded or towed, that being said the usual suspects are:
6. Check for generated fault codes.
For more information about your issue please visit the websites below. Good luck and have a nice day.
ZUMAFORUMS NET View topic Help My 2009 Zuma 125 won start
http://z125data.weebly.com/uploads/7/1/2/2/7122816/zuma_125_service.pdf
OEM parts for Yamaha
Yamaha Zuma YW125A Owner Manual
Mar 19, 2012 | 2009 Yamaha Zuma 125
TV remote won't work. Batteries are OK. LG remote not programmed to change channels
Is it the original remote of the TV? or an "all in one" type???, if it's the original remote you don't need programming, if the batteries are fresh and correctly installed, than check the InfraRed output with the help of a camera... The human eye cannot see IfraRed but cameras do... so point the remote to anny camera (with video capabilities) and press the buttons on the remote, if you see the IR Lights flashing through the camera, than the remote is working, if not than the remote is dead, check for cold joint solders inside or buy an all in one remote...
Aug 09, 2011 | LG 42LC2D 42 in. LCD HDTV
The head lights flash rapidly, the inside panel light flash, cd player works intermittently
Check and clean battery terminals...if its a total power failure, intermittent or flashing, I'd go to the source of power...the battery.
Jul 31, 2011 | 2006 Ford Freestyle
My nokia 7230 is not starting, my daught had put it in a water but not soaked in water i removed it imm and dried, it was working then, except for the up n left navigation key and the disconnect button so...
Hi, when ever a phone drops inside the water, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.
You will need to service the phone for the phone to be free from water,cause if the water dries inside the phone it will damage an IC or a chip inside the phone and it might cause more damage to the phone.
After, disassembling the phone is the next step.
Get a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.
Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
After some minutes,assemble the phone back and fix in the battery. Make sure during the processyou are charging the battery of the phone.
I guess that's all you need.
Note: if the battery has stayed too too long on the phone and am sorry after the water splash, it might not come on after this all process, that means you will have to flash the phone because the battery might have damaged the memory of the board of the phone and will not power up the phone because the phone is too weak to power.
Flashing of the phone will restore back the phone memory.
You can visit the below link to learn more about flashing of phones.
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jul 26, 2011 | Nokia 7230 Cell Phone
All panel lights flashing. Printer seems to initialize, then reverts to all lights flashing.
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
May 29, 2009 | Epson Stylus Color 640 InkJet Printer
Generac 14,000 watt Automatic Standby Generator Logo
16 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
