Question about HP DeskJet F380 All-In-One Printer
Printer not woking as it should
Although both cartriges are installed correctly there is no color and printer eats multipe papers at a time
I need this driver please
Posted on Jan 28, 2009
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
Just had my color cartridge refilled, and reinstalled correctly. However, the printer will not print with the color cartridge in, but will print with the black cartridge only.
your newly installed cartrige which is the colored one is not detected or mybe damage....may i ask if how many times did you refill already your cartrige?refilling a cartrige can cause damage to its circuit i suggest purchase a new colored cartrige and see if it works.
Oct 09, 2009 | HP DeskJet 845c Printer
Paper alarm; printer keeps printing same job
remove all supply and then plug then attach data cable, uninstall printer driver and install again
Jun 18, 2009 | Canon MF8180C Color Laser MFC Printer
Paper
Regular paper is fine for day to day printing. Although, highly graphical printing, or printing that uses a lot of ink will look much better on the inkjet paper, as it doesn't 'bleed' through it nearly as much.
Apr 11, 2009 | Canon Office Equipment & Supplies
Fairly new toner and display reads "Install black cardtricge"
I have just resolved the "Install black cartrige" issue on my printer I am not sure if it will solve everyone's problem but these are the steps I took to solve the problem.
1. removed the black cartrige.
2. removed all the paper from the tray and noticed that one of the pages was a little jammed.
3. I then turned the printer on and off again and still encountered the "Install black cartrige" error message.
4. I then put the black cartrige back in the the printer and restarted the printer.
5. When the printer restarted it started to initialize correctly and I perform some test prints to confirm that it was back up and running.
Apr 07, 2009 | HP LaserJet M1522nf Multifunction Printer...
Error message on lcd screen won't print
Try to clean inside the printer especially the rollers may some time small piece left or remain ..
Jan 16, 2009 | Samsung SCX-4100 All-In-One Laser Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
PRINT command
uninstall ink with printer on and turn off then back on when printer says install ink do so if that doesnt work clean contacts with rubbing alcohl on ink cartriges.
Dec 08, 2007 | Dell 922 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
