Question about Samsung TV Remote Control
Bn59-00901a How to unlock the menu
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Sep 29, 2016 | LG Cell Phones
How do i unlock Sony w2oo after synchronization?
1. Turn on the your phone whithout sim card
2. Lock screen
3. Press sequence: Menu, Back, Back, Menu, Back, Menu, Menu, Back
4. Select Service info
5. Select SimLock
6. Check where is X
7. If X is on NETWORK and value is difrent than zero, you can unlock phone.
8. If it is zero unlock by code is NOT available. The counter is blocked.
1. Turn on the phone whithout sim card
2. Type *#*#7378423#*#*
3. Select Service info
4. Select SimLock
5. Check where is X
6. If X is on NETWORK and value is difrent than 0, you can unlock your phone.
7. If it is 0 unlock by code is NOT possible.
The counter is blocked. How to unlock Sony Ericsson W200i Walkman sim unlock net
Feb 07, 2015 | Sony Ericsson W200i Cellular Phone
My menu control is locked and i want to know how to unlock this dell P2210t
pressing the Menu button takes you directly to the OSD settings menu. You should then select the Unlock option to unlock and allow user access to all applicable settings
Aug 27, 2014 | Dell P2210 Monitor
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Cheats for tiger woods pga tour 07
Lol ok here we go....Press (L1) and then go to password in the options. At the password screen enter these names.
Crowd with big headsPress [L1] at the main menu screen, then choose Password from the options menu.
tengallonhat: Crowd will have big heads
CheatsPress [L1] at the main menu screen, then choose Password from the options menu and enter the following words to unlock the following items:
THREE STRIPES: Unlock All Adidas ItemsSHOJIRO: Unlock All Bridgestone ItemsSNAKEKING: Unlock All Cobra ItemsJUST SHAFTS: Unlock All Grafalloye ItemsINTHEGAME: Unlock All Level 3 EA Sports ItemsMACTEC: Unlock All Macgergor ItemsRIHACHINRZO: Unlock All Mizuno ItemsJUSTDOIT: Unlock All Nike ItemsJANNARD: Unlock All Oakley ItemsLIGHTNING: Unlock All PGA Tour ItemsSOLHEIM: Unlock All Ping ItemsGAMEFACE: Unlock All Players in Team PlayGUYS ARE GOOD: Unlock All Precept ItemsMR ADAMS: Unlock All Taylormade Items
ALSO IF YOU...**Successfully complete the game with a 100% completion you can unlock the EA Black Series Clubs.**
**At the 17th green at Sahalee, you can see Bigfoot hiding behind a tree.** LOL!!
I hope this helps :D
Dec 01, 2011 | Sony Playstation 3 (PS3) Console
I forgot the code
this is all lg hard reset code you much enter it
LG
2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...)
2945#(*)- hold (LG 500,600)
B1200 *+pwr, 6,6,8 Service Menu
B1300 *+pwr, 1,5,9 Service Menu
Security Removing Code For Lg 8110,8120.
47328545454#
Or
277634#*#
LG
47328545454#
Or
277634#*#
U8180 old ...............49857465454#
U8180 new .............492662464663#
U8330 ...................637664#*#
U8360 ...................*6*41*12##
U8380 ...................525252#*#
ALL LG 2G : 2945#*#
8110 & 8120 : 277634#*#
U8130 & U8138 : 47328545454#
8180 old sw : 49857465454#
8180 new sw : 492662464663#
8330 : 637664#*#
8360 : *6*41*12##
8380 : 525252#*#
LG 8550 885508428679#*#
Phone
Service Menu Code
8110 277634#*#
8120 277634#*#
8130 47328545454#
8138 47328545454#
8180 v10A 49857465454#
8180 v11A 492662464663#
8330 637664#*#
8360 *6*41*12##
8380 525252#*#
Phone
Unlock Menu Code
Older phones 2945#*88110#
U880
was told that unlocking code for the phone is "0794070061"
and method is to enter 142358#*#
but when i enter above code instead of asking for nck code it restarts(phone is temporary unlocked with sim inside).
Plz help how to unlock it permanently
Mar 03, 2011 | LG Dare VX9700 Cell Phone
I need the sim unlock code for my lg optimus p509
Hello, LG all models test mode:
Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Simlock menu (LG B1200): 1945#*5101#
Simlock menu (LG 510W, 5200): 2945#*5101#
Simlock menu (LG 7020, 7010): 2945#*70001#
Simlock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'SW Ver.info'
Code to reset phone :
- Phone without SIM
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | LG Cell Phones
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
Looking for cheat codes for midnightclub3 dub edition remix cheats that we can use on our playstation2
  • All cities in arcade mode Enter the options screen and select the "Cheats" option. Enter "roadtrip" or "crosscountry" at the cheat menu to unlock all cities in arcade mode.
  • Increase car mass in arcade mode Enter the options screen and select the "Cheats" option. Enter "hyperagro" at the cheat menu.
  • No damage Enter the options screen and select the "Cheats" option. Enter "ontheroad" at the cheat menu.
  • Faster pedestrians Enter the options screen and select the "Cheats" option. Enter "urbansprawl" at the cheat menu. Note: This code also unlocks all cities in arcade mode.
  • Argo special move Enter the options screen and select the "Cheats" option. Enter "dfens" at the cheat menu to unlock the Argo special move.
  • Roar special move Enter the options screen and select the "Cheats" option. Enter "Rjnr" at the cheat menu to unlock the Roar special move.
  • Zone special move Enter the options screen and select the "Cheats" option. Enter "allin" at the cheat menu to unlock the Zone special move.
  • Bunny head Enter the options screen and select the "Cheats" option. Enter "getheadl" at the cheat menu.
  • Flaming head Enter the options screen and select the "Cheats" option. Enter "trythisathome" at the cheat menu.
  • Pumpkin head Enter the options screen and select the "Cheats" option. Enter "getheadk" at the cheat menu.
  • Skull head Enter the options screen and select the "Cheats" option. Enter "getheadn" at the cheat menu.
  • Snowman head Enter the options screen and select the "Cheats" option. Enter "getheadm" at the cheat menu.
  • Yellow smile head Enter the options screen and select the "Cheats" option. Enter "getheadj" at the cheat menu.
  • Chrome body Enter the options screen and select the "Cheats" option. Enter "haveyouseenthisboy" at the cheat menu.
  • Add $1 to career money total Enter the options screen and select the "Cheats" option. Enter "kubmir" at the cheat menu. Note: If you have a controller with an auto-fire feature, you can use it to get more money easily. Go to the cheat menu and enter "kubmir". Then, press R2 and set the word "kubmir" to the top slot. Next, set R2 and X to auto-fire. Tape down the R2 and X and allow the game to remain in that state.
  • Subtract $1 from career money total Enter the options screen and select the "Cheats" option. Enter "rimbuk" at the cheat menu.
  • Chevy Cobalt SS Win the Unbeatable Street Racers tournament in Tokyo Challenge mode to unlock the Chevy Cobalt SS.
  • Dodge Magnum Win the Ginza tournament in Tokyo Challenge mode to unlock the Dodge Magnum.
  • Gemballa F355 Win the By Invitation Only tournament in Tokyo Challenge mode to unlock the Gemballa F355.
  • Hotmatch Chingon Win the Choppers Of America tournament in Tokyo Challenge mode to unlock the Hotmatch Chingon.
  • Hummer H3T Win the Big Playas tournament to unlock the Hummer H3T.
  • Nissan Skyline 02 Win all thirteen Unbeatable Street Racers races to unlock the Nissan Skyline 02.
  • Nissan Sport Concept Win the Class C Vehicles Only tournament to unlock the Nissan Sport Concept.
  • Paul Smart Sports Bike Win the Original Riders tournament to unlock the Paul Smart Sports Bike.
  • Tokyo Police Car Win all tournaments in Tokyo Challenge mode to unlock the Tokyo Police Car.
  • Feb 19, 2009 | Sony PlayStation 2 (PS2) Console
    Lg unlocked '
    If it's the childlock, you can change that in the menu.
    cheers, Gerard
    Nov 07, 2008 | LG 42LC2D 42 in. LCD HDTV
    Samsung TV Remote Control Logo
    Jerry Greenberg
    Jerry Greenberg
