Question about Whirlpool LGR8648 Gas Dryer
Gas Dryer quit heating today
Gas Dryer:
Whirlpool LGR8648
Today it quit heating?
What to look at first?
Thermal Fuse?
Igniter?
Gas Valve Coils?
Thermostats?
I have the dryer apart
  • mj_wahlmeier Jan 31, 2009
    Fix the dryer! Did continuity test on thermal fuse. It was blown! Replace and all is well.
    Regards,
  • 2,071 Answers
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Posted on Jan 28, 2009
We have an LGR8648 gas dryer. When you start the dryer, it heats up just fine. At some point (after 15-20 minutes, it seems) the burner goes out and never comes back on. Is there a thermal sensor or...
The most common cause for your problem is the gas valve coils. There are 2 and should be replaced in pairs. Over time, they will fire when you first start the dryer but fail to fire again once in mid cycle. A link for a typical set of coils is listed below:
Whirlpool Gas Valve Coil Set of 2
Jul 24, 2011 | Whirlpool LGR8648 Gas Dryer
Have a Whirlpool LGR4634EQ1 dryer and it all of a sudden stop heating up
There are quite a few things to check on a gas dryer.
  1. Gas valve coils
  2. Igniter
  3. Flame Sensor
  4. Thermal Fuse
  5. High Limit Thermostat
  6. Cycling Thermostat
Here is a video to walk you thru the process of doing the diagnostics on the dryer to find the failed component.
Dec 31, 2010 | Whirlpool LGV4634JQ Gas Dryer
What to do when dryer runs but does not heat up
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse , coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go.
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Whirlpool LGR5636L Gas Dryer
Dryer will not heat gas
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 28, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlppol model LGV6634BWO gas, no heat
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jul 26, 2009 | Dryers
Gas dryer-no heat. whirlpool lgr4634eq3. can i
Advise your landlord of the issue and follow his/her instructions.
I have provided some information on trouble shooting the dryer No Heat issue.
Below is a checklist provided by; www.repairclinic.com.
They also provide repair parts, disassembly procedures and diagrams for DIY repairs.
Firstly, ascertain that you have made a positive heat selection, then read on.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jul 12, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer not heating up
Check the following areas to address this issue.
1. Gas valve coils
2. Thermal fuse
3. Igniter
If all the above check out ok, replace the timer or, control board.
Jun 17, 2009 | Whirlpool Dryers
Gas Dryer does not continue to heat.
Check the Following to address this issue--
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 02, 2009 | Whirlpool Dryers
No flame but igniter cycles
Igniter
Gas valve coils
Thermal fuse
May 28, 2009 | Dryers
Dryer working but no heat
If it does not heat , and you already checked the burner and the ignitor, then it is probably the thermal fuse at the back of the appliance.
See the following suggestions from Repairclinic:
No heat If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Oct 09, 2008 | Dryers
Whirlpool LGR8648 Gas Dryer Logo
1,037 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
