Boiler pilot out on rayburn 480 ag
Pilot light won't stay on on the boiler side of the rayburn - have pressed reset button - pilot lights, then immediately goes out, then comes on. then goes out and so on......
SOURCE: Rayburn 480 ag, pilot goes out
rayburn nouvelle thermocouple keeps burning out any suggestions
Posted on Mar 15, 2010
SOURCE: pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Posted on Sep 21, 2011
  • 7 Answers
SOURCE: gas fireplace pilot light won't stay light or
The first thing to change would be the Thermo-coupler
Posted on Oct 20, 2011
SOURCE: Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Posted on Feb 07, 2012
mechanicsonl
  • 431 Answers
SOURCE: my pilot light is weak and won't stay lite.
try cleaning the pilot light jet, usually gets dust etc inside it. clean it with a pin. but remember do not mess with gas appliances if you are not confident enough. as being cold will be the least of your worries lol
Posted on Feb 16, 2012
Testimonial: "Thank you, i will give that a try..."
Rayburn problems
if the pilot flame onto the thermocouple is 2 small [partialy blocked pilot feeder orifice] this will cause your described symptoms also flame 2 far from t/couple ! Tip of flame farthest from pilot burner should touch and slightly overlap tip of thermocouple
Dec 23, 2013 | Heating & Cooling
Boiler pilot light won't stay lit
Power can be on just turn the room thermostat down .
Apr 06, 2017 | Burnham IN5S-SP-EZ-NG IN5, 86,000 BTU...
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
Feb 07, 2012 | Heating & Cooling
Pilot light on the gas boiler won't stay lit it's
Sep 20, 2011 | Heating & Cooling
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Dec 25, 2009 | Kitchen Ranges
Pilot light has gone out onmy Ideal Elan 2 Boiler
TAKE A SHPO VAC AND CLEAN AREA. MAKE SURE YOU PAY SPECIAL ATT. TO THE PILOT LIGHT. FIND BUTTON HOLD IN AND IGNITE DONT LET GO WHEN IT LIGHTS FOR AT LEAST FIFTEEN SEC.. YOU MIGHT ALSO HAVE TO TURN THE THERMASTAT OR KNOB TO PILOT FIRST. AFTER IT HAS LIT TURN UP FLAME
Oct 25, 2008 | Water Heaters
Heating & Cooling Logo
257 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
