Question about Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
How to install dry filter to model 5275 10 gal shop vac
MakikiChris
  • 84 Answers
SOURCE: emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Posted on Aug 02, 2007
Pyrhyc
  • 2028 Answers
SOURCE: Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Posted on Jul 16, 2008
SOURCE: Shop Vac Model 758.17871
I'm assuming you have a paper filter. If so, take it out to **** up water. The water will ruin the paper filter.Usually they will dry if you put it out to dry but there isn't any reason to keep it in the vac for water. Depending on what you are sucking up with it, if you are indoors especially, monitor the "blowing hole" when you start to make sure it is not throwing dirt out. If what you are sucking is mostly water then it should not do that.
Posted on Mar 15, 2009
  • 120 Answers
SOURCE: using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Posted on Sep 16, 2009
kitt98
  • 26 Answers
SOURCE: How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Posted on Nov 05, 2009
How do I remove the filter from a Rigid 4 gal portable wet/dry vac
James the attached link/video shows filter just pulls off. I also put a link to the manual and it show the filter held on with large plastic nut, which would have to be removed first.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
4 Gallon Portable Wet Dry Vac
http://www.ridgidparts.com/pdf/WD40500.pdf
Rigid WD4070 Wet Dry Shopvac Unboxing and Overview
RIDGID Shop Vac Review must have tool 2
Apr 30, 2016 | Filter Vacuums
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
Need filter for craftsman6hp. 16 gal shop vac model 113.177060
They're availabe at Sears and Kmart. Lowes and Home Depot also have filters that will work.
Dec 27, 2012 | Craftsman 17765 Canister Wet/Dry Vacuum
How to use 9 gal wet/dry for wet use?
to use for 'wet' use --- just remove the foam and paper filter from the inside of the unit. it is now ready for wet use.
make sure you let the unit dry out before you reinstall the filters and use it for dry use.
c...
Feb 15, 2011 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
Genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Mar 11, 2010 | Genie Company GV150 Wet/Dry Vacuum
Automatic pump for 10 gal shop vac
first you have to remove the filter in the vac then at the bottom of the vac tyhere should be a cap you remove and screw a water hose on and run it out side then when the vac fills the water will run out put the main hose on the suction side
Mar 21, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
I would suggest it if it gets dirty muddy you can always clean the filter alot easier than replaceing vac
Dec 21, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum Logo
63 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
