Question about Sony PlayStation 2 (PS2) Console
Ps2 disk tray
When i turn on my ps2 the disk tray open, closes and opens again and won't do anything else. how can i fix this
  • 118 Answers
To me if you have the old fat PS2's then it sounds like the motors are worn out. You can't fix this unless it's still under warranty and call PlayStation. But if not under warranty, try to seel it to like a pawn shop or something to get cash and I recommend getting the slim PS2. The disc tray pops open like the PS1, and the only thing that can mess that up is it getting something spilled in it to make it sticky. I've had mine for about 5 years now and it hasn't messed up at all. But make sure not to play burnt discs on it or it will get used to them and not play regular discs. Hope this solves!
Posted on Jan 30, 2009
My 360 kinect won't read disks. It says open tray,
my x box 360 Kinect want work because when I put the game in it said open and close the tray
Apr 08, 2012 | Video Game Consoles & Games
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
My ps2 disk tray keeps opening up.. and when i close it it opens again. what do i doo?
You have problem with tray latch. There are two latches i.e. left and right ( you see when you open the tray). Check whether they broke in pieces or chipped . You may need to good glue to to have them fixed.
Dec 04, 2010 | Sony PlayStation 2 (PS2) Console
Green Light will not stay on when I close PS2 slim tray
That sounds like a damaged wire that may be grounding out when you close the tray. Do you have the larger (older) PS2 or the slim one?
Jul 10, 2010 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slim disk only spins if door is a little bit open, I even put something on it so that it won open or shuts completely, because if it does, then it doesn't work,for reference, it was...
tray problem can be solved by opening the ps2
1. unscrew all the screw open the body
2. on the upper body u can see a spring on the tray
just clean the spring (dust particles)
3.cover the tray check whether it is working
Mar 22, 2010 | Sony PlayStation 2 (PS2) Console
Ok my playstation 2 disk tray will open only half it wan't close
it is tray problem,
its easy , unscrew all, carefully open from one side(sometime u unplug the powercable) ,so slowly remove cover ,
u can see the drive on the right , there will be 4 screw remove it now u can see thadjusment
od the left side u see screw which remove the tray
rearrange the tray again and apply some oil on the runner that it then fix it, try the tray without closing
Mar 18, 2010 | Sony PlayStation 2 (PS2) Console
When I turn on the power to the PS2, the disk tray immediately opens. I put in a disk and close it, after 2 seconds it opens again as if I hit the eject button. The tray won't stay shut.
i would check if your eject button is stuck if it is try to pull it out a little with small plyers or its the eject sensor or finally it might also have something in the way of the tray if you dropped it on accident or something it will keep opening if something is in the way. hope this helps.
Dec 23, 2009 | Sony PlayStation 2 (PS2) Console
Disk tray opens and closes repeatedly
Jan 18, 2009 | Sony PlayStation 2 (PS2) Console
PS2 disk tray keeps opening
try holding the disk drive after it closes for a few seconds and see if it stays closed or one of the drives gears could be stuck,loose,or might need to open it up.
Jul 05, 2007 | Sony Playstation 3 (PS3) Console
PS2 disk tray problem
This has happened to me before. You will have to open the PS2 and clean the laser which is under the tray(or on top i forgot).
Use a cotton bud to clean it but be extreamaly careful cause if you put to much pressure on the laser your PS2 is gone for good!
Jul 05, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
